2013-03-16 01:14 PM
Nexus5010が再起動後、"Loader>"の表示となり、
CCOにある手順でSystem Image をLOADさせましたが、
System Imageが正常に起動しません。
HW 故障?
操作手順は以下です。
Loader Version pr-1.3
loader> dir
bootflash:
lost+found
n5000-uk9-kickstart.5.1.3.N2.1c.bin
n5000-uk9.5.2.1.N1.3.bin
n5000-uk9.5.1.3.N2.1c.bin
n5000-uk9-kickstart.4.2.1.N2.1a.bin
n5000-uk9.4.2.1.N2.1.bin
loader> boot bootflash:n5000-uk9-kickstart.4.2.1.N2.1a.bin
Booting kickstart image: bootflash:n5000-uk9-kickstart.4.2.1.N2.1a.bin....
....................................................................Image verif
ication OK
Starting kernel...
Usage: init 0123456SsQqAaBbCcUu
INIT: version 2.85 booting
I2C - Mezz absent
blogger: /var/log/isan.log: No such file or directory (2).
Starting Nexus5020 POST...
Executing Mod 1 1 SEEPROM Test......done
Executing Mod 1 1 GigE Port Test.......done
Executing Mod 1 1 Inband GigE Test.....done
Executing Mod 1 1 NVRAM Test....done
Executing Mod 1 1 PCIE Test..............................done
Mod 1 1 Post Completed Successfully
Mod 3 Post Completed Successfully
POST is completed
Creating /callhome..
Mounting /callhome..
Creating /callhome done.
Callhome spool file system init done.
Checking all filesystems..... done.
Loading system software
INIT: Sending processes the KILL signalFS kernel daemon...don
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
switch(boot)#
switch(boot)# dir
16384 Mar 15 2013 11:51:39 lost+found/
20816384 Mar 16 2013 02:50:13 n5000-uk9-kickstart.4.2.1.N2.1a.bin
34365952 Mar 15 2013 11:58:43 n5000-uk9-kickstart.5.1.3.N2.1c.bin
182813420 Mar 16 2013 03:17:19 n5000-uk9.4.2.1.N2.1.bin
90177536 Mar 16 2013 02:45:58 n5000-uk9.5.1.3.N2.1c.bin
173248174 Mar 15 2013 12:23:37 n5000-uk9.5.2.1.N1.3.bin
Usage for bootflash: filesystem
563646464 bytes total used
319705088 bytes free
883351552 bytes available
switch(boot)# load bootflash:n5000-uk9.4.2.1.N2.1.bin
INIT: Sending processes the TERM signal
INIT: (boot)#
INIT: Sending processes the KILL signaldaemon...don
switch(boot)#
以上
2013-03-25 03:58 PM
kickstart imageとsystem imageのversionが異なっているために起動できていないと思われます。
kickstart: n5000-uk9-kickstart.4.2.1.N2.1a.bin
system: n5000-uk9.4.2.1.N2.1.bin
一旦同じversionのimageが揃っている以下のversionで起動すれば良いかと思います。
