取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
15
回复
vmanger能够ping通但是WEB无法打开
xiaomaomao05086
vmange配置完后,能够ping通,但是WEB无法打开,https的服务也开了,请问大家有谁知道是什么问题吗?
15 条回复15
你可以先看看配置或证书是否有问题?
show run
show control local-properties
看看服务示范都处于running?
request nms all status
另外,是否有在VPN0开启tunnel接口?
https://sdwan-docs.cisco.com/Product_Documentation/Software_Features/Release_17.2/04Segmentation/02Configuring_Segmentation_(VPNs)
看看有没有用呢?
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
xiaomaomao05086
1540488497lcj 发表于 2020-3-3 19:01
你可以先看看配置或证书是否有问题?
show run
vmanage# show control local-properties
personality vmanage
sp-organization-name
organization-name
root-ca-chain-status Installed
certificate-status Not-Installed
certificate-validity Not Applicable
certificate-not-valid-before Not Applicable
certificate-not-valid-after Not Applicable
dns-name
site-id 0
domain-id 0
protocol dtls
tls-port 23456
system-ip 0.0.0.0
chassis-num/unique-id 3208082f-bfed-40e3-9ec2-57aac3f521a0
serial-num No certificate installed
cloud-hosted no
token -NA-
retry-interval 0:00:00:16
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped FALSE
time-since-last-port-hop 0:00:00:00
number-vbond-peers 0
number-active-wan-interfaces 0
vmanage#
vmanage#
vmanage#
vmanage#
vmanage#
vmanage#
vmanage#
vmanage# request nms all status
^@NMS application server
Enabled: true
Status: running PID:9347 for 671s
NMS configuration database
Enabled: true
Status: running PID:8289 for 684s
NMS coordination server
Enabled: true
Status: running PID:5551 for 706s
NMS messaging server
Enabled: true
Status: running PID:7488 for 689s
NMS statistics database
Enabled: true
Status: running PID:3432 for 717s
NMS data collection agent
Enabled: true
Status: running PID:10910 for 656s
NMS cloud agent
Enabled: true
Status: running PID:465 for 733s
NMS container manager
Enabled: false
Status: not running
NMS SDAVC proxy
Enabled: true
Status: running PID:551 for 733s
vmanage#
vmanage#
vmanage#
vmanage#
已经为VPN0配置了IP地址,并且也设置为了tunnel inteface,也能ping通这个地址,但是就是web无法打开,请问是因为证书服务没有安装吗?如何安装这个证书
xiaomaomao05086 发表于 2020-3-4 17:42
已经为VPN0配置了IP地址,并且也设置为了tunnel inteface,也能ping通这个地址,但是就是web无法打开 ...
那这个设备应该还没加入overlay吧?
你访问的时候,是访问8443端口吗?
https://system-ip-address:8443/
虚拟机的分配的磁盘和内存有多大呢?
xiaomaomao05086
你访问的时候,是访问8443端口吗?
https://system-ip-address:844 ...
我虚拟机分配的资源如下所示:
2vCPU
32G内存
200G硬盘
我用https://xx.xx.xx.xx:8443也无法打开WEB页面
被这个问题都搞疯了。
xiaomaomao05086
你访问的时候,是访问8443端口吗?
vmanage# show running-config
system
host-name vmanage
admin-tech-on-failure
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
user admin
password $6$j5Bg15pfyVjD2XGS$3TIqc8ZDo7T7/D/cgLgZ/nutmvCwNSVZ7bsP2F71NdTY/nhQC8VC4JB76xvybVIW615pcclx0xEWDyki7oSdZ1
logging
disk
enable
vpn 0
dns 114.114.114.114 primary
interface eth0
ip address 172.30.20.201/16
ipv6 dhcp-client
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service netconf
no allow-service ntp
no allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 172.30.0.1
vpn 512
vmanage#
vmanage#
这是我的全部配置
wuhao0015
1,你在VPN0还是在VPN512上做的配置?
先把tunnel interface去掉,或者allow-service https
2,用的什么版本你的内存给够了没?
3,到vshell下看看服务和端口又没起来?
vmanage:~$ netstat -tnal | grep 8443
tcp6 0 0 :::8443 :::* LISTEN
wuhao0015
我做实验从0到站点之间做通,硬撸文档做了一周,里面各种坑,最难搞的就是PKI和加vedge。
xiaomaomao05086
2,用的什么 ...
1.我在VPN0上做的IP地址访问,把tunnel interface去掉了还是不行,之前一直有allow-service https,但是还是不行;
2.用的版本是19.1.0
3.这个vshell的后台怎么进入
4.我的整机配置文件如下:
system
host-name vmanage
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
logging
disk
enable
vpn 0
interface eth0
ipv6 dhcp-client
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service https
no shutdown
vpn 512
vmanage#
vmanage#
xiaomaomao05086
请问在哪里可以获取到文档
xiaomaomao05086
2,用的什么 ...
硬件参数分配我觉得已经够大了
2VCPU
32G内存
200G硬盘
wuhao0015
xiaomaomao05086 发表于 2020-3-5 08:56
请问在哪里可以获取到文档
1,我是硬啃的官方文档
2,vshell直接在cli下敲vshell
3,telnet 8443端口是否能通?
4,是不是浏览器或者防火墙的原因,实在不行再重新部署个只配置个地址直连。
xiaomaomao05086
wuhao0015 发表于 2020-3-5 12:04
1,我是硬啃的官方文档
vmanage:~$
vmanage:~$
vmanage:~$
vmanage:~$
vmanage:~$
这是不是端口没有起来,这个端口能更改吗?
目前已经是直连了。
xiaomaomao05086
问题已解决,使用的版本是19.1.0,换用版本,换用18.4.3然后同样的配置,GUI已经可以正常打开
感谢楼主分享解决方案,是否有小伙伴的回答也令您满意呢?您可以标记为最佳哦
快捷链接
