你好,这个应该是不行的。具体请参考如下官方解释:
Set the Tenancy Mode for a vManage Server
[float=left][/float]Save as PDF
Contents []
Related Articles
Change the IP Address of the vManage NMS
Add a vManage NMS to a vManage Cluster
Configure Organization Name
Add, Delete, or Edit a Tenant
Configure the DNS Name or IP Address of the vBond Orchestrator
To place the vManage server in multitenant mode so that you can manage the overlay networks of multiple tenants, use the vManage Administration ► Settings screen.
By default, the vManage server is in single tenant mode, which enables it to manage a single overlay network.
- Click the Edit button to the right of the Tenancy Mode bar.
- In the Tenancy field, click Multitenant.
- In the Domain field, enter the domain name for the service provider (for example, viptela.com).
- Click Save. The vManage server reboots and comes back up in multitenant mode.
Note: After you place a vManage server into multitenant mode, you cannot convert it back to single-tenant mode. <<<<<<<<<<<<<
To configure tenants, go to the Administration ► Tenant Management screen.
Release InformationIntroduced in vManage NMS in Release 17.2.
https://sdwan-docs.cisco.com/Product_Documentation/vManage_How-Tos/Configuration/Set_the_Tenancy_Mode_for_a_vManage_Server
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
