отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Просмотры
Полезный материал
Ответы
Magiox
Beginner
Не стартует Cisco Catalyst 2960x TS-L 24
Спойлер
File "flash:/c2960x-universalk9-mz.152-6.E3.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(6)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Mon 15-Jul-19 03:19 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 10 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 690688
mifs[7]: Bytes available : 1115648
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 971264
mifs[8]: Bytes available : 2899456
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 22 files, 2 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 57259008
mifs[11]: Bytes available : 64926720
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
extracting ucode_info (76 bytes)
front_end/ (directory)
extracting front_end/fe_type_9 (81125 bytes)
Front-end Microcode IMG MGR: Installed 2 image(s) in cache:
Front-end Microcode IMG MGR: found microcode images for 2 devices.
Image for front-end 0: flash:/front_end_ucode_cache/ucode.0
Image for front-end 14: flash:/front_end_ucode_cache/ucode.0
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...28824 bytes.
Front-end Microcode IMG MGR: Programming device 0...rwRrrrrrrwsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspwRr!
Front-end Microcode IMG MGR: Microcode programming complete for device 0.
Front-end Microcode IMG MGR: Microcode programming complete.
POST: MA BIST : Begin***ERR: MBIST Result is not all 0(0x400000).
POST: MA BIST : End, Status Failed
POST: BIST failed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
driver class subsystem initialization failed
04:50:24 UTC Fri Apr 13 2035: Unexpected exception to CPUvector 300, PC = 38E6664
-Traceback= 0x38E6664z 0x37D8054z 0x37D4738z 0x37D1250z 0x2CB267Cz 0x2CB2858z 0x2CB29D0z 0x7F1EF0z 0x7F2118z 0x3AC515Cz 0x3AC0E4Cz
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_21
=== Flushing messages (04:50:28 UTC Fri Apr 13 2035) ===
Buffered messages:
Queued messages:
Apr 13 04:50:28.201: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:33.589: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.153: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Apr 13 04:49:32.120: in Switch 0. Cannot read pid from Flexstack module
Apr 13 04:50:24.811: %PLATFORM_IPC-3-COMMON: Init failed before IPC init
-Traceback= 7E0290z 3435360z 3584050z 2CB267Cz 2CB2858z 2CB29D0z 7F1EA8z 7F2118z 3AC515Cz 3AC0E4Cz
Apr 13 04:50:24.877: platform assert failure: 0: ../src-hulc/src-strider/strider_hqatm.c: 6428: strider_hqatm_set_snap_bridging
Apr 13 04:50:24.877: -Traceback= 7E1704z 3581A1Cz 37ED2B0z 3430FC8z 2CB267Cz 2CB2858z 2CB29D0z 7F1EF0z 7F2118z 3AC515Cz 3AC0E4Cz
Data Access Exception (0x0300)!
SRR0 = 0x038E6664 SRR1 = 0x00029200 SRR2 = 0x03D0DD20 SRR3 = 0x00029200
ESR = 0x00800000 DEAR = 0x00000B00 TSR = 0x84000000 DBSR = 0x00000000
CPU Register Context:
Vector = 0x00000300 PC = 0x038E6664 MSR = 0x00029200 CR = 0x48000028
LR = 0x037D8054 CTR = 0x0071004C XER = 0x2000001A
R0 = 0x780A43A6 R1 = 0x08C81920 R2 = 0x00000000 R3 = 0x00000B00
R4 = 0x00000000 R5 = 0x00042805 R6 = 0xC0000B00 R7 = 0x0000000A
R8 = 0x7C7043A6 R9 = 0x00000010 R10 = 0x010A0170 R11 = 0x000A0000
R12 = 0x0000000B R13 = 0x1F183AF4 R14 = 0x007F20BC R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x080E0000
R28 = 0x00000000 R29 = 0x08C81950 R30 = 0x00000000 R31 = 0x080DF3F4
Stack trace:
PC = 0x038E6664, SP = 0x08C81920
Frame 00: SP = 0x08C81928 PC = 0x0071003C
Frame 01: SP = 0x08C81940 PC = 0x037D4738
Frame 02: SP = 0x08C81988 PC = 0x037D1250
Frame 03: SP = 0x08C81998 PC = 0x02CB267C
Frame 04: SP = 0x08C819B8 PC = 0x02CB2858
Frame 05: SP = 0x08C819D0 PC = 0x02CB29D0
Frame 06: SP = 0x08C81A00 PC = 0x007F1EF0
Frame 07: SP = 0x08C81B00 PC = 0x007F2118
Frame 08: SP = 0x08C81B08 PC = 0x03AC515C
Frame 09: SP = 0x00000000 PC = 0x03AC0E4C
Switch uptime is 1 minute, 37 seconds
cisco WS-C2960X-24TS-L (APM86XXX) processor (revision G0) with 524288K bytes of memory.
Processor board ID FCW1912A3TJ
Собственно лог
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Leonid Voronkin
VIP Collaborator
Это аппаратная проблема. Если есть сервисный контракт - то RMA. Если нет, то либо чинить у каких-то умельцев, либо на помойку
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Просмотреть решение в исходном сообщении
1 ОТВЕТ 1
Leonid Voronkin
VIP Collaborator
Не удалось отобразить этот виджет.
