yushimaz
    今回紹介する事例は、ACE  module FT の設定を行い、Traffic を流すと、ACE module を搭載している Switch (supervisor) CPU 使用率が高くなるという現象です。
    Switch 2 台にそれぞれ ACE module を挿入し、使用している user が多いですが、機器の都合上、今回は 1 台の Switch 上に 2 枚の ACE module を挿入し確認します。
    # 構成
    # Switch 設定 (今回の試験に関係のある部分のみ抜粋)
    sup720#sh run | i svclc
    svclc    autostate
    svclc    multiple-vlan-interfaces
    svclc module    4 vlan-group 1
    svclc module    6 vlan-group 1
    svclc    vlan-group 1  771-773
    sup720#
    sup720#sh run int gi 1/31
    Building    configuration...
    Current    configuration : 162 bytes
    interface    GigabitEthernet1/31
    switchport
    switchport access vlan 771
    switchport mode access
    no ip address
    load-interval 30
    end
    sup720#sh run int gi 1/35
    Current    configuration : 144 bytes
    interface    GigabitEthernet1/35
    switchport
    switchport access vlan 772
    no ip address
    end
    sup720#sh run int vl 773
    Current    configuration : 66 bytes
    interface    Vlan773
    ip address 192.168.73.250 255.255.255.0
    end
    sup720#
    # ACE 設定(active)
    ACE20a/Admin#    sh run
    Generating    configuration....
    peer hostname    ACE20b
    hostname    ACE20a
    boot system    image:c6ace-t1k9-mz.A2_3_1.bin
    resource-class    sticky
      limit-resource all minimum 0.00 maximum    unlimited
      limit-resource sticky minimum 1.00 maximum    unlimited
    context Admin
      member sticky
    access-list    all line 8 extended permit ip any any
    rserver host    sv1
      ip address 192.168.72.50
      inservice
    serverfarm    host sf
      rserver sv1
        inservice
    sticky    http-cookie ace ace_cookie
      serverfarm sf
    class-map    match-all vip
      2 match virtual-address 192.168.71.100 any
    policy-map    type loadbalance first-match lb
      class class-default
        sticky-serverfarm ace_cookie
    policy-map    multi-match client-vips
      class vip
        loadbalance vip inservice
        loadbalance policy lb
        loadbalance vip icmp-reply
    access-group    input all
    interface    vlan 771
      ip address 192.168.71.251 255.255.255.0
      alias 192.168.71.250 255.255.255.0
      peer ip address 192.168.71.252    255.255.255.0
      service-policy input client-vips
      no shutdown
    interface    vlan 772
      ip address 192.168.72.251 255.255.255.0
      alias 192.168.72.250 255.255.255.0
      peer ip address 192.168.72.252    255.255.255.0
      no shutdown
    ft interface    vlan 773
      ip address 192.168.73.251 255.255.255.0
      peer ip address 192.168.73.252    255.255.255.0
      no shutdown
    ft peer 1
      heartbeat interval 300
      heartbeat count 10
      ft-interface vlan 773
    ft group 1
      peer 1
      priority 110
      associate-context Admin
      inservice
    # ACE 設定(standby)
    ACE20b/Admin#    sh run
    peer hostname    ACE20a
    hostname    ACE20b
    context Admin
      member sticky
    rserver host    sv1
      inservice
    serverfarm    host sf
      rserver sv1
        inservice
      serverfarm sf
      class class-default
      class vip
    interface    vlan 771
      peer ip address 192.168.71.251    255.255.255.0
      no shutdown
    interface    vlan 772
      peer ip address 192.168.72.251    255.255.255.0
      no shutdown
      peer ip address 192.168.73.251    255.255.255.0
      no shutdown
    ft peer 1
      heartbeat count 10
    ft group 1
      peer 1
      peer priority 110
      inservice
    # client からの Traffic
    # httperf --server 192.168.71.100    --port 80 --uri /index.html --rate 700 --num-conn 20000 --num-call 10
    # Switch rate cpu 使用率
    sup720#sh int gi 1/31 | i rate
      Queueing strategy: fifo
      30 second input rate 4850000 bits/sec,    5401 packets/sec
      30 second output rate 11670000 bits/sec,    4687 packets/sec
    sup720#sh proc c sort 5sec
    CPU    utilization for five seconds: 19%/14%; one    minute: 6%; five minutes: 3%
    !___ 5Mbps 程度の Traffic が入ってきただけで、CPU 使用率が 20% 程度まで上昇しています。
    !___ また、割り込み処理で 14% CPU 使用率を消費しています。
    PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
    123      838468  12765193         65  4.07%  1.20%  0.56%   0 IP Input
       9     1960588  19609098         99  0.15%  0.12%  0.14%   0 ARP Input
       3         324       566        572  0.07%  0.09%  0.06%   0 Exec
    118     2662528   2728514        975  0.07%  0.04%  0.02%   0 CDP Protocol
    176      320172    281876       1135  0.07%  0.00%  0.00%   0 SNMP ENGINE
    sup720#sh int vl 773
    Vlan773 is    up, line protocol is up
      Hardware is EtherSVI, address is    0016.9c6d.e580 (bia 0016.9c6d.e580)
      Internet address is 192.168.73.250/24
      MTU 1500 bytes, BW 1000000 Kbit, DLY 10    usec,
         reliability 255/255, txload 1/255,    rxload 1/255
      Keepalive not supported
      Last input 00:00:00, output 00:00:23,    output hang never
      Last clearing of "show    interface" counters never
      Input queue: 0/75/2628/2005    (size/max/drops/flushes); Total output drops: 0
    !___ vlan 773 input queue    drop が発生
      Output queue: 0/40 (size/max)
      5 minute input rate 482000 bits/sec, 254    packets/sec
      5 minute output rate 0 bits/sec, 0    packets/sec
      L2 Switched: ucast: 6928 pkt, 1221580    bytes - mcast: 1295873 pkt, 293490902 bytes
      L3 in Switched: ucast: 0 pkt, 0 bytes -    mcast: 0 pkt, 0 bytes mcast
      L3 out Switched: ucast: 0 pkt, 0 bytes    mcast: 0 pkt, 0 bytes
         2609114 packets input, 519657046 bytes,    0 no buffer
         Received 2609114 broadcasts (0 IP    multicasts)
         0 runts, 0 giants, 9 throttles
         0 input errors, 0 CRC, 0 frame, 0    overrun, 0 ignored
         141 packets output, 11302 bytes, 0    underruns
         0 output errors, 4 interface resets
         0 output buffer failures, 0 output    buffers swapped out
    vlan 773 で Input queue drop が発生していることから、vlan 773 に流れ込む Traffic Process  switching (CPU 処理) されている可能性が疑われます。 そこで、buffer を確認してみると、下記出力のように dest mac がすべて F broadcast packet FT interface 間で流れています。 これは、ACE 間でやり取りを行っている heartbeat packet connection 情報を同期するための packet になります FT の設定を行うと自動的に UDP 9 connection TCP 1 connection connection table に登録され、ACE 間の情報のやり取りに使用されます。
    # Switch buffer  情報
    sup720#show buffers input-interface vl    773 packet
    Buffer    information for Small buffer at 0x44CB77F8
      data_area 0x8048DC4, refcount 1, next    0x44D8B898, flags 0x280
      linktype 7 (IP), enctype 1 (ARPA), encsize    14, rxtype 1
      if_input 0x47288B08 (Vlan773), if_output    0x0 (None)
      inputtime 2d17h (elapsed 12w1d)
      outputtime 9w4d (elapsed 3w0d), oqnumber    65535
      datagramstart 0x8048E3A, datagramsize 60,    maximum size 308
      mac_start 0x8048E3A, addr_start 0x8048E3A,    info_start 0x0
      network_start 0x8048E48, transport_start    0x8048E5C, caller_pc 0x41876F04
      source: 192.168.73.251, destination:    192.168.73.252, id: 0x1D62, ttl: 254,
      TOS: 0 prot: 17, source port 50002,    destination port 50000
    08048E30:                      FFFF FFFFFFFF            ......
    08048E40:    00070E0F 2CA10800 4500002C 1D620000  ....,!..E..,.b..
    08048E50:    FE118A16 C0A849FB C0A849FC C352C350  ~...@(I{@(I|CRCP
    08048E60:    00180000 000100C0 00000008 00000000  .......@........
    08048E70:    0000012C 000043                      ...,..C
    Buffer    information for Medium buffer at 0x44DD3480
      data_area 0x81B8384, refcount 1, next    0x44E21A00, flags 0x280
      inputtime 00:00:00.000 (elapsed never)
      outputtime 00:00:00.000 (elapsed never),    oqnumber 65535
      datagramstart 0x81B83FA, datagramsize 230,    maximum size 460
      mac_start 0x81B83FA, addr_start 0x81B83FA,    info_start 0x0
      network_start 0x81B8408, transport_start    0x81B841C, caller_pc 0x41876F04
      source:    192.168.73.251, destination: 192.168.73.252, id: 0x3911, ttl: 254,
      TOS: 0 prot: 17, source port 50302,    destination port 50300
    081B83F0:                      FFFF FFFFFFFF            ......
    081B8400:    00070E0F 2CA10800 450000D8 39110000  ....,!..E..X9...
    081B8410:    FE116DBB C0A849FB C0A849FC C47EC47C  ~.m;@(I{@(I|D~D|
    081B8420:    00C40000 02020280 000100BC 00000000  .D.........<....
    081B8430:    0303000F F7759C39 000FF775 91EB0800  ....wu.9..wu.k..
    081B8440:    45000028 00000000 00060000 C0A84732  E..(........@(G2
    081B8450:    C0A84764 E6360050 00000000 02F1B52B  @(Gdf6.P.....q5+
    081B8460:    50020000 00000000 00000008 05B40206  P............4..
    081B8470:    00080480 24450000 19200030 00000000  ....$E... .0....
    081B8480:    00000000 E488920D 00000000 C0A84832  ....d.......@(H2
    081B8490:    C0A84732 06010009 0050EA21 7B8CB6F3  @(G2.....Pj!{.6s
    081B84A0:    00110000 05B40000 00080480 24450005  .....4......$E..
    081B84B0:    16D00030 00000000 00000000 7B8CB6F3  .P.0........{.6s
    081B84C0:    00000000 00000000 00050000 00270000  .............'..
    081B84D0:    30203139 3A32313A 31372047 4D540D0A  0    19:21:17 GMT..
    081B84E0:    FF                                   .
    Buffer    information for Medium buffer at 0x501BBD20
      data_area 0x821C7E4, refcount 1, next 0x0,    flags 0x280
      datagramstart 0x821C85A, datagramsize 230,    maximum size 460
      mac_start 0x821C85A, addr_start 0x821C85A,    info_start 0x0
      network_start 0x821C868, transport_start    0x821C87C, caller_pc 0x41876F04
      source: 192.168.73.251, destination:    192.168.73.252, id: 0x60AB, ttl: 254,
    0821C850:                       FFFF FFFFFFFF            ......
    0821C860:    00070E0F 2CA10800 450000D8 60AB0000  ....,!..E..X`+..
    0821C870:    FE114621 C0A849FB C0A849FC C47EC47C  ~.F!@(I{@(I|D~D|
    0821C880:    00C40000 02020280 000100BC 00000000  .D.........<....
    0821C890:    0303000F F7759C39 000FF775 91EB0800  ....wu.9..wu.k..
    0821C8A0:    45000028 00000000 00060000 C0A84732  E..(........@(G2
    0821C8B0:    C0A84764 EE200050 00000000 957C8582  @(Gdn .P.....|..
    0821C8C0:    50020000 00000000 00000008 05B40206  P............4..
    0821C8D0:    00082480 24450000 3ED0004F 00000000  ..$.$E..>P.O....
    0821C8E0:    00000000 7636FBD2 00000000 C0A84832  ....v6{R....@(H2
    0821C8F0:    C0A84732 06010009 005083BC A57646A5  @(G2.....P.<%vF%
    0821C900:    00110000 05B40000 00080480 24450005  .....4......$E..
    0821C910:    16D0004E 00000000 00000000 A57646A5  .P.N........%vF%
    0821C920:    204D6F6E 2C203037 204A756E 20323031   Mon, 07 Jun 201
    0821C930:    30203139 3A32313A 31372047 4D540D0A  0    19:21:17 GMT..
    0821C940:    57                                   W
    # FT 設定時の ACE connection 情報
    ACE20a/Admin# show conn
    total current    connections : 11
    conn-id    np dir proto vlan source                destination           state
    99         1  in  UDP   773  192.168.73.252:50000  192.168.73.251:50002  --
    100        1  in  UDP   773  192.168.73.252:50100  192.168.73.251:50102  --
    101        1  in  UDP   773  192.168.73.252:50300  192.168.73.251:50302  --
    102        1  in  UDP   773  192.168.73.252:50300  192.168.73.251:50301  --
    103        1  in  UDP   773  192.168.73.252:50200  192.168.73.251:50202  --
    97         2  in  UDP   773  192.168.73.252:50100  192.168.73.251:50101  --
    98         2  in  UDP   773  192.168.73.252:50300  192.168.73.251:50302  --
    99         2  in  UDP   773  192.168.73.252:50300  192.168.73.251:50301  --
    100        2  in  UDP   773  192.168.73.252:50200  192.168.73.251:50201  --
    101        2  in  TCP   773  192.168.73.251:32801  192.168.73.252:2000   ESTAB
    102        2  out TCP   773  192.168.73.252:2000   192.168.73.251:32801  ESTAB
    ACE20a/Admin#
    ACE20a/Admin#
    今回の事象は、ACE 間でやり取りされているFT packet broadcast であるため、それを受信した vlan 773 で process switching され、CPU 使用率が上昇していました。 これは、vlan 773 shutdown するか、設定を削除することで回避できます。
    # SVI 設定削除後の CPU 使用率
    sup720#conf t
    Enter    configuration commands, one per line.  End with CNTL/Z.
    sup720(config)#no int vl 773
    sup720(config)#end
    sup720#
      30 second input rate 6101000 bits/sec,    6793 packets/sec
      30 second output rate 14680000 bits/sec,    5888 packets/sec
    sup720#sh proc c | i second
    CPU    utilization for five seconds: 2%/1%; one    minute: 1%; five minutes: 1%
    !___ 流れている traffic    rate は先ほどより多いにもかかわらず CPU 使用率は低いまま
    sup720#
シスコ コミュニティをいち早く使いこなしていただけるよう役立つリンクをまとめました。みなさんのジャーニーがより良いものとなるようお手伝いします:
世界を支援するプログラムに参加しましょう
