# stcli license show all
Smart Licensing Status
Smart Licensing is ENABLED
License Reservation is ENABLED <--------------
SLRリクエストコードを生成
SLRモードを有効にしたら、以下のコマンドでリクエストコードを生成します。
# stcli license reservation request
Enter the following reservation request code into the CSSM:
CP-PHX220C-M5SX,............................-B6jnU5MNT-22
# stcli license reservation return
This command will remove the license reservation authorization code and the cluster will transition back to the unregistered state. Are you sure you wish to continue [y/n]?y
Enter the following reservation return code into the CSSM:
CQoJST-XXXXXXXXXXXXXXXXXXXXXXXXXXXX-Buc
リターンコードを再度表示させたい場合は、以下のコマンドで確認します。
# stcli license show reservation
Last Return Code:CQoJST-XXXXXXXXXXXXXXXXXXXXXXXX-Buc
