2011-06-30 11:59 PM
my question is, if we have not added vlan 5 on our switch, but we are excecuting the command "switport mode access vlan 5", wat error will this command give, plz help me its urgent
I assume its a Cisco switch... So it will create a VLAN itself when u entered the Command switchport access vlan 5
you will get a message like this when you entering a command switch port access vlan <no> in any of the interfaces.
Switch(config-if)#switchport access vlan 3
% Access VLAN does not exist. Creating vlan 3
Hope this helps
Rate this answer if it is helpful
下記より関連するコンテンツにアクセスできます
