取消
显示结果
搜索替代
您的意思是:
查看次数
20
有帮助
回复
#分享达人# 3850堆叠的一下注意事项
fortune
VIP Expert VIP Expert
VIP Expert
3850交换机堆叠,如果是首次堆叠,必须要形成菊花链,不能是单条堆叠线路,如果是单线路则报错如下:
设备无法正常开机。
堆叠形成之后,一根堆叠线路坏了还可以继续正常使用!
堆叠配置:
堆叠重新选择:
An active switch retains its role unless one of these events occurs:
• The switch stack is reset.
• The active switch is removed from the switch stack.
• The active switch is reset or powered off.
• The active switch fails.
• The switch stack membership is increased by adding powered-on standalone switches or switch stacks.
The active switch is elected or reelected based on one of these factors and in the order listed:
1 The switch that is currently the active switch. (已经是Master)
2 The switch with the highest stack member priority value. (高优先级)
3 The switch with the shortest start-up time. (先启动)
4 The switch that has the configuration file.(有配置文件)
5 The switch with the lowest MAC address.(低MAC地址)
Default Switch Stack Configuration
switch 3 renumber 4
reload slot 4
switch 3 priority 2 (The priority value range is 1 to 15. )
The new priority value helps determine which stack member is elected as the new active switch when the current active switch or switch stack resets
show switch
新设备加入前可以修改好设备number
Switch(config)# switch 3 provision WS-xxxx // 1 - 9
通过 no switch 3 provision 删除配置
禁用堆叠端口:
switch 2 stack port 1 disable
switch 2 stack port 1 enable
1 条回复1
tony_tan
Beginner
Beginner
感谢分享,:)
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
认可您的同行
快捷链接
