取消
显示结果
搜索替代
您的意思是:
公告
December 2020
December 2020
3481
查看次数
68
有帮助
回复
hansons
Beginner
Cisco 4506 RX Power Low Warning
最近发现cisco 4506E 出现如下问题:现象:
SW001#show interfaces transceiver module 2
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Tx Power Rx Power
Port (Celsius) (Volts) (dBm) (dBm)
Gi2/5 30.9 3.30 -5.9 -15.6
Gi2/11 30.3 3.29 -5.8 -14.5
Gi2/12 31.0 3.29 -5.9 -18.2
Gi2/18 29.7 3.29 -6.5 -18.8
Gi2/20 29.2 3.29 -5.7 -10.5
SW001#show logging
Log Buffer (32768 bytes):
value: -40.0 dBm, Threshold value: -21.0 dBm.
.Mar 12 00:00:50.603: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/12: Rx power low warning; Operating value: -18.7 dBm, Threshold value: -17.0 dBm.
.Mar 12 00:10:25.143: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/5: Rx power low warning; Operating value: -20.1 dBm, Threshold value: -17.0 dBm.
.Mar 12 00:10:35.720: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/18: Rx power low warning; Operating value: -19.0 dBm, Threshold value: -17.0 dBm.
.Mar 12 00:10:50.708: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/12: Rx power low warning; Operating value: -19.0 dBm, Threshold value: -17.0 dBm.
.Mar 12 00:20:25.243: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/5: Rx power low warning; Operating value: -19.9 dBm, Threshold value: -17.0 dBm.
.Mar 12 00:20:35.822: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/18: Rx power low warning; Operating value: -19.0 dBm, Threshold value: -17.0 dBm.
操作:
(1)更换SFP 模块,警告问题还是存在
(2)更换SFP模块尾纤,警告问题还是存在
请问下哪位遇到此类似问题?该怎么解决呢?:)
10 条回复10
wyc_chao
Beginner
肯定是光纤光衰比较大,换光纤,光换尾纤没有用的
YilinChen
Advocate
收光太弱,2端都要查原因,光衰有点大;LZ没有描述现网拓扑情况,推测近期是否有线缆或其它业务割接?
Rockyw
Advisor
18653465190
Enthusiast
运营商那边的光路接入检查过没有?可以让运营商从局端打光测试。
shuangbao wang
Rising star
出现告警的时候可以用光功率计测试一下收光,如果收光不正常,那就是线路或对端设备问题,如果收光正常还存在告警,那就是本端设备问题了。
LxL9905
Beginner
遇到过这种类似情况,但是换了新模块好了
将来的你,
   将要感谢现在努力拼搏奋斗的自己!
sillything
Beginner
运营商的光纤资源的话,找营运商的检测下光纤光衰。假如是自己的光纤资源,找施工或者熔接光纤的人测试光衰。
limingkui
Beginner
确认不是本端问题后,查下对端设备发光功率情况,有可能是对端光模块或尾纤问题。
hansons
Beginner
sillything 发表于 2020-4-17 08:38
运营商的光纤资源的话,找营运商的检测下光纤光衰。假如是自己的光纤资源,找施工或者熔接光纤的人测试光衰 ...
的确,通过施工方到现场使用FLUKE networks optical Fiber pro 测试仪器测试主干道的光纤,就发现主干道光缆存在Failed,且loss packets 严重。
最终更换主干道光缆就恢复正常啦。
谢谢!(* ̄︶ ̄)
hansons
Beginner
显然的,通过施工方使用FLUKE networks optical fibers pro 测试仪,测试主干道光缆状态,就发现loss(dB)非常严重。最终判断是主干道的光缆有问题。
通过重新布置新的光缆,通信可以恢复正常了。
如图示:
Content for Community-Ad
不能显示该小部件。
