取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
15
回复
堆叠交换机和防火墙做port-channel出错
seasonli72658
链路聚合失败谁帮忙分析一下是哪里出了问题谢谢:
Port state = Up Cnt-bndl Suspend Not-in-Bndl
Channel group = 7 Mode = On Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po7
Port index = 0 Load = 0x00 Protocol = -
Age of the port in the current state: 0d:00h:18m:26s
Probable reason: trunk mode of Gi1/0/10 is dynamic, Po7 is access
Port: Gi2/0/10
Age of the port in the current state: 0d:00h:06m:41s
Probable reason: trunk mode of Gi2/0/10 is dynamic, Po7 is access
Port-channels in the group:
Port-channel: Po7
Age of the Port-channel = 0d:00h:22m:19s
Logical slot/port = 12/7 Number of ports = 0
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Not-Inuse
Protocol = -
Port security = Disabled
端口配置:
SW3650堆叠核心交换机
interface Port-channel2
switchport access vlan 209
switchport mode access
spanning-tree portfast---这个命令配置不上去
应用到下面两个端口上interface port-channel2
interface GigabitEthernet1/0/10
channel-group 2 mode on
interface GigabitEthernet2/0/10
ASA5515防火墙
nameif inside
security-level 100
ip address 10.99.209.1 255.255.255.248
应用到这两个端口下interface port-channel2
interface GigabitEthernet0/1
interface GigabitEthernet0/4
interface Vlan209
ip address 10.99.209.4 255.255.255.248
配置上去ping 10.99.209.4是通的,但是ping10.99.209.1就不通
这两个channel配置上去交换机的灯由绿灯变为黄灯了这四个端口
15 条回复15
YilinChen
Port: Gi2/0/10
报错提示已经有了呀,检查交换机上对应端口配置,其中G1/0/10端口下缺配置,没封装802.1q
seasonli72658
Port: Gi2/0/10
除了没封装之外其他的还需要更改吗
还有能帮我看一下ASA防火墙配置有问题吗
ASA5515防火墙
nameif inside
security-level 100
seasonli72658
Port: Gi2/0/10
spanning-tree portfast 这个命令是不是不用配置了
还有一个问题就是链路聚合一端channel配置VLAN ,别一端channel配置的是IP这个会有影响吗。
YilinChen
还有一个问题就是链路聚合一端channel配置VLAN ,别 ...
清除所有垃圾配置
2端PortChannel要么全是三层,要么都是Trunk透VLAN
seasonli72658
YilinChen 发表于 2019-10-29 08:35
清除所有垃圾配置
nameif inside
security-level 100
policy-route route-map rmap-to-Liantong
如果做链路聚合的话,问一下上面这三条是配置在port-channel下面呢,还是配置在端口下面
YilinChen
在Portchannel下进行配置
seasonli72658
YilinChen 发表于 2019-10-29 13:47
在Portchannel下进行配置
非常感谢,我试一下晚上,这个问题已经弄了好久了,一直不好用,
nameif inside
security-level 100
上面这个对端的配置三层核心交换上的端口配置
channel-group 2 mode on 只配置这个可以吗,和上面的端口互联
YilinChen
nameif inside
security-level 100
请详细描述问题现象,包括连线拓扑、对应相关接口配置、要实现的功能等,谢谢
seasonli72658
好的稍等我画一下图,等我一下谢谢
seasonli72658
seasonli72658 发表于 2019-10-29 14:28
好的稍等我画一下图,等我一下谢谢
ASA5515 old-vPn设备配置:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 140.207.0.28 255.255.255.248
nameif inside
security-level 100
interface GigabitEthernet0/2
nameif VPN
security-level 0
no ip address
interface GigabitEthernet0/3
nameif inside1
security-level 100
ip address 10.99.210.1 255.255.255.248
用同网段连接的方法:
路由写了优先级
route inside 10.88.0.0 255.255.0.0 10.99.209.4 1
route inside1 10.88.0.0 255.255.0.0 10.99.210.4 6
route inside 10.99.0.0 255.255.0.0 10.99.209.4 1
route inside1 10.99.0.0 255.255.0.0 10.99.210.4 6
这个主要用来走VPN的,主要实现哪个堆叠交换挂了都可以正常让VPN连进来
ASA5515 new配置
interface Port-channel1
nameif inside
security-level 100
ip address 10.99.201.1 255.255.255.248
no nameif
no security-level
no ip address
no nameif
主要实现连接堆叠交换机,做链路聚合,哪个堆叠交换挂 了都可以正常上外网
3650堆叠配置
no switchport
ip address 10.99.201.4 255.255.255.248
interface GigabitEthernet1/0/18
interface GigabitEthernet2/0/18
上面是链路聚合端口连接ASA5515 new
同网段连接端口用来连接ASA5515 old-vPn
switchport access vlan 210
vlan:
interface Vlan209
interface Vlan210
ip address 10.99.210.4 255.255.255.248
VPN路由:
ip route 192.168.2.0 255.255.255.0 10.99.209.1 1
ip route 192.168.2.0 255.255.255.0 10.99.210.1 6
seasonli72658
麻烦帮忙看一下,这样配置有没有问题,因为我这里配置要停网,不能总测试,所以帮忙看一下这样还哪里有问题吗
seasonli72658
Port: Gi2/0/10
今天我配了防火墙的protchannel但是在写
nameif inside这个命令打不上,提示不能在空接口配置nameif这个是什么意思
ASA5515-SH-new(config)# interface Port-channel1
ASA5515-SH-new(config-if)# nameif inside
ERROR: nameif not allowed on empty etherchannel interface.
ASA5515-SH-new(config-if)# security-level 100
ASA5515-SH-new(config-if)# ip address 10.99.201.1 255.255.255.248
ASA5515-SH-new(config-if)# policy-route route-map rmap-to-Liantong
虽然
nameif inside没有配置上,但是我把channel配置到接口上了下面是日志:下面的LOG是不是代表链路聚合成功了
Group state = L3
Ports: 2 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: -
Minimum Links: 0
Ports in the group:
Port: Gi1/0/18
Port state = Up Mstr In-Bndl
Channel group = 1 Mode = On Gcchange = -
Port-channel = Po1 GC = - Pseudo port-channel = Po1
Age of the port in the current state: 0d:00h:17m:28s
Port: Gi2/0/18
Age of the port in the current state: 0d:00h:17m:05s
Port-channel: Po1
Age of the Port-channel = 0d:00h:18m:15s
Logical slot/port = 12/1 Number of ports = 2
Passive port list = Gi1/0/18 Gi2/0/18
Port state = Port-channel L3-Ag Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi1/0/18 On 0
0 00 Gi2/0/18 On 0
Time since last port bundled: 0d:00h:17m:05s Gi2/0/18
能告诉我 interface Port-channel1下面怎么才能配置上:nameif inside吗谢谢
YilinChen
贴了图,可还是思维描述混乱,是2台ASA 都有和 3650 建立链路聚合的需求,还是只其中一台ASA有这样的需求?
光看现有配置,为什么ASA5515 NEW上,物理接口下配置是channel-group2, 楼主却非得在PortChannel 1里配命令?
seasonli72658
YilinChen 发表于 2019-10-30 15:04
贴了图,可还是思维描述混乱,是2台ASA 都有和 3650 建立链路聚合的需求,还是只其中一台ASA有这样的需求? ...
不好意思,是写错了,物理接口下配置是channel-group1,就两个防火墙都要和堆叠交换机建立链路聚合的需求,现在解决了ASA5515 NEW链路聚合的问题,别一个也就搞定了,能帮我看看吗,ASA5515 NEW的防火墙链路聚合的问题
快捷链接
