My c4506 reload ,i want know the reason for reload
sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(20)EW4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 13-Oct-06 11:30 by tinhuang
Image text-base: 0x00000000, data-base: 0x012B3810
ROM: 12.2(31r)SG2
Dagobah Revision 226, Swamp Revision 32
1-Dist-4506-B uptime is 4 hours, 33 minutes
System returned to ROM by reload
System restarted at 05:08:57 UTC+8 Fri Feb 21 2025
System image file is "bootflash:/cat4000-i5k91s-mz.122-20.EW4.bin"
你好,
通过基本的信息可以判断这里应该是手动重启有关系。重启时间是 Fri Feb 21 2025,也就是今天05:08:57 。
System returned to ROM by reload <<<<<<<<<<<<
你的show ver信息应该还没输出完成。完整的信息里面应该还有“Last reset from xxx” 这个描述信息,可以进一步参考这个信息判断。
如果有AAA的话,可以看看那会儿是哪个账号登录进了设备。
当然如果是设备Crash导致的重启的话,可以看看设备是否有crashinfo,一般会存在bootflash里面。dir bootflash:应该可以看到。
或者:
show platform crashdump 也可以看看有无Crash的记录。
this is completed output,it has not "Last reset from xxx"
this is show platform crashdump:
------------------ show platform crashdump ------------------
Last powerfail: 12/30/2012 22:16:32
Current time: 02/21/2025 00:59:50
Last crash: 02/20/2025 20:24:42
Build: 12.2(20)EW4
buildversion addr: 01973338
pc=00DD1B94 lr=00DD1B94 msr=00029030 vector=00000700
cr=82000044 ctr=0123ACE4 xer=20000000
r0=00DD1B94 r1=20012198 r2=FFFFFFFF r3=00000047
r4=00000020 r5=00000000 r6=20012160 r7=00000000
r8=00000001 r9=2001221F r10=2001221F r11=01E7FCD8
r12=A1021530 r13=FFFFFFFF r14=002CC224 r15=00000000
r16=00000000 r17=01980000 r18=00000001 r19=00000001
r20=01AF0000 r21=01AF0000 r22=0189573C r23=019B0E00
r24=019B0A00 r25=200122DC r26=20012298 r27=200121A4
r28=019731A0 r29=200121B8 r30=200122B8 r31=050025A4
dec=FBD5B3D8 tbu=001BC8F7 tbl=183C623C
dar=00000000 dsisr=00000000 hid0=8000C000
ErrDr1=00 ErrDr2=00 ErrStsCpu=72 ErrStsPci=00
BusErrAddr=E8000900
Single bit ECC count 0
Stack frames:
Frame 1: pc=0128B53C stack=20012268
Frame 2: pc=00DDB2A4 stack=20012270
Frame 3: pc=0124C9A8 stack=20012300
Frame 4: pc=0124C800 stack=20012310
Frame 5: pc=002F7E98 stack=20012318
Frame 6: pc=002F6D14 stack=019B2434
Frame 7: pc=00005534 stack=019B246C
Frame 8: pc=00000000 stack=2033CC18
Frame 9: pc=00DD2420 stack=2033CCF0
Frame 10: pc=00DD21F4 stack=2033CE08
Frame 11: pc=0128B584 stack=2033CEE8
Frame 12: pc=012333F4 stack=2033CEF0
Frame 13: pc=012B0288 stack=2033CF20
Frame 14: pc=00D65938 stack=2033CF28
Frame 15: pc=00D659A0 stack=2033CF30
Frame 16: pc=002CBFAC stack=2033CF38
Frame 17: pc=002CC210 stack=2033CF90
Frame 18: pc=002CC2C0 stack=2033CFA8
Frame 19: pc=002563F8 stack=2033CFD8
Frame 20: pc=002508B4 stack=2033CFE0
Pushed stack:
20012190: 20012268 00DD1B94
200121A0: 019701A8 019730C0 00000003 00000000
200121B0: 200121B8 00000000 019730A0 200121D8
200121C0: 00000000 00000001 00000047 00000052
200121D0: 00000000 00000000 0A466174 616C204E
200121E0: 464C2045 72726F72 204E464C 20303038
200121F0: 30303430 30204644 54312030 30303030
20012200: 30303020 46445432 20303030 30303030
20012210: 3020464C 44203030 30424631 38310A00
20012220: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
20012230: 20012270 00800400 00800400 00000000
20012240: 00000000 000BF181 00000000 00000000
20012250: 00000000 20012278 05002588 00000002
20012260: 200122B8 050025A4 20012270 0128B53C
20012270: 20012300 00DDB2A4 00000000 00000000
20012280: 00000001 5555552E FFFFEFFF 55055555
20012290: EFFFFFFF BEFDFFBF 00000080 40000000
200122A0: 00000000 00000000 00000000 00000000
200122B0: 00000000 00000000 00000080 40000000
200122C0: 00000000 00000000 00000000 00000000
200122D0: 00000000 00000000 00800400 00800000
200122E0: FFFFFFFF 01895730 01AE9088 00000000
200122F0: 018AC3B8 00000000 01AF0000 065B4420
20012300: 20012310 0124C9A8 FFFFFFFF 01AE9088
20012310: 20012318 0124C800 019B2434 002F7E98
20012320: FFFFFFFF FFFFFFFF
Popped stack:
20011F90: 00000010 D9DE502C
20011FA0: FFFFFFFF 01340000 01B20000 022F6218
20011FB0: 00000000 00000000 20011FC0 022F6340
20011FC0: 20011FF8 00228FF0 FFFFFFFF 00000001
20011FD0: 04000000 20011FF8 20011F68 022AF2A8
20011FE0: 03000000 20011FF8 20012000 0023F0C0
20011FF0: 200120B8 200121B8 20012000 01F2EAF0
20012000: 20012018 002C9554 00009B00 00009B00
20012010: 20012018 019A8E90 20012020 002FB9A4
20012020: 20012030 002FBAB4 20012160 0000000A
20012030: 20012038 002C9B90 20012048 002C9C54
20012040: 00000049 0000000A 20012058 001C1684
20012050: 200120C8 FFFFFFFE 200120F0 001BEEC0
20012060: 022AF2A8 00000000 200120D8 000001F4
20012070: 002CC224 00000000 00000000 01980000
20012080: 00000001 00000001 01AF0000 01AF0000
20012090: 0189573C 019B0E00 00000000 200122DC
200120A0: 20012220 200121A4 002CC224 00000000
200120B0: 00000000 01980000 00000001 00000001
200120C0: 01AF0000 01AF0000 0189573C 019B0E00
200120D0: 019B0A00 200122DC 20012298 200121A4
200120E0: 019731A0 200121B8 200122B8 FFFFFFFE
200120F0: 20012188 001C19C0 20012198 0124EF90
20012100: 00000000 20011FD0 00000000 00000000
20012110: 00D64CBC 2001221F 019701A8 00000001
20012120: 00000049 C826DFCC 022AF2A8 00000000
20012130: FFFFFFFF 00000000 00000000 01980000
20012140: 00000001 00000001 01AF0000 01AF0000
20012150: 0189573C 019B0E00 019B0A00 200122DC
20012160: 02000000 20012190 200120F8 200121A0
20012170: 02000000 20012190 200120F8 200121A0
20012180: 20012100 050025A4 20012190 002D4A90
20012190: 20012198 00D64CD0
Log buffer:
Wed Feb 12 2025
CMD: 'sh mac address-table add' 10:36:05 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table address 0432.019e.8290' 10:36:13 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table address add 0432.019e.8290' 10:36:17 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp 0432.019e.8290' 10:36:24 UTC+8 Wed Feb 12 2025
CMD: 'sh vlan' 10:37:12 UTC+8 Wed Feb 12 2025
CMD: 'sh mac add' 10:40:58 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table in' 10:40:59 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table interface f6/31' 10:41:01 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table interface po6' 10:41:07 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp 204c.03be.cbf6' 10:41:15 UTC+8 Wed Feb 12 2025
CMD: 'sh cdp ne' 10:41:22 UTC+8 Wed Feb 12 2025
CMD: 'sh cdp neighbors po6' 10:41:23 UTC+8 Wed Feb 12 2025
CMD: 'sh cdp neighbors po6 de' 10:41:27 UTC+8 Wed Feb 12 2025
CMD: 'sh cdp neighbors po6 detail ' 10:41:27 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp | in 10.60.8.5' 10:44:30 UTC+8 Wed Feb 12 2025
CMD: 'cle' 10:44:34 UTC+8 Wed Feb 12 2025
CMD: 'clear ip arp' 10:44:37 UTC+8 Wed Feb 12 2025
CMD: 'clear ip arp 10.60.8.5' 10:44:40 UTC+8 Wed Feb 12 2025
CMD: 'sh run in' 10:45:20 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp | in 10.60.8.5' 10:45:42 UTC+8 Wed Feb 12 2025
CMD: 'ping 10.60.8.5' 10:46:55 UTC+8 Wed Feb 12 2025
CMD: 'sh run' 10:48:14 UTC+8 Wed Feb 12 2025
CMD: 'help ip arp 10.60.8.5' 10:52:39 UTC+8 Wed Feb 12 2025
CMD: 'clear ip cache 10.60.8.5 255.255.255.0' 10:52:51 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp | in' 10:56:38 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp | include 10.60.8.5' 10:56:43 UTC+8 Wed Feb 12 2025
CMD: 'sh ip arp | include 10.60.8.5' 11:01:19 UTC+8 Wed Feb 12 2025
CMD: 'sh mac add' 13:23:23 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table add' 13:23:23 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table address 9457.a55e.23f0' 13:23:24 UTC+8 Wed Feb 12 2025
CMD: 'sh mac add' 13:40:24 UTC+8 Wed Feb 12 2025
CMD: 'sh mac address-table add' 13:40:25 UTC+8 Wed Feb 12 2025
CMD: 'ping 10.60.8.5' 13:45:58 UTC+8 Wed Feb 12 2025
CMD: 'sh mac add' 13:38:34 UTC+8 Fri Feb 14 2025
CMD: 'sh mac address-table add' 13:38:34 UTC+8 Fri Feb 14 2025
CMD: 'sh mac address-table address 58ce.2a8c.0bb3' 13:38:35 UTC+8 Fri Feb 14 2025
CMD: 'sh cdp ne' 13:38:39 UTC+8 Fri Feb 14 2025
CMD: 'sh eth' 13:38:42 UTC+8 Fri Feb 14 2025
CMD: 'sh etherchannel c' 13:38:44 UTC+8 Fri Feb 14 2025
CMD: 'sh etherchannel s' 13:38:45 UTC+8 Fri Feb 14 2025
CMD: 'sh cdp ne' 13:38:49 UTC+8 Fri Feb 14 2025
CMD: 'sh cdp neighbors g2/21' 13:38:51 UTC+8 Fri Feb 14 2025
CMD: 'sh cdp neighbors g2/22 de' 13:38:58 UTC+8 Fri Feb 14 2025
CMD: 'sh cdp neighbors g2/22 detail ' 13:38:58 UTC+8 Fri Feb 14 2025
CMD: '' 13:39:07 UTC+8 Fri Feb 14 2025
CMD: 'sh run in' 13:39:08 UTC+8 Fri Feb 14 2025
CMD: 'sh run interface g2/21' 13:39:11 UTC+8 Fri Feb 14 2025
CMD: 'sh proc' 15:42:34 UTC+8 Fri Feb 14 2025
CMD: 'sh processes cpu his' 15:42:36 UTC+8 Fri Feb 14 2025
CMD: 'sh processes cpu history ' 15:42:36 UTC+8 Fri Feb 14 2025
CMD: 'sh ip arp su' 15:42:43 UTC+8 Fri Feb 14 2025
CMD: 'sh pla' 15:44:47 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu' 15:44:49 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu pac' 15:44:50 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet r' 15:44:52 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet ' 15:44:53 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet dr' 15:44:57 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet driver ' 15:44:57 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet ' 15:46:18 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet sta' 15:46:21 UTC+8 Fri Feb 14 2025
CMD: 'sh platform cpu packet statistics ' 15:46:22 UTC+8 Fri Feb 14 2025
Malloc / Free trace:
1 . pc=001B3524 addr=0759BE68
2 . pc=002AAA50 addr=08BAC708
3 . pc=0036D474 addr=08A86660
4 . pc=200005D0 addr=08A86660
5 . pc=0036DE44 addr=08B34130
6 . pc=2000008C addr=08B34130
7 . pc=0036E900 addr=08B34130
8 . pc=6000020C addr=08D28748
9 . pc=0036D878 addr=08D28310
10. pc=0036D474 addr=08D28310
11. pc=20000428 addr=08D28310
12. pc=0036DE44 addr=08B34130
13. pc=2000008C addr=08B34130
14. pc=0036E900 addr=08B34130
15. pc=600003B4 addr=08A86A98
16. pc=0036D878 addr=08A86660
17. pc=002AAA50 addr=08BAC708
18. pc=0068BBE0 addr=08DD4220
19. pc=0068BBD8 addr=08D08358
20. pc=00A343E4 addr=08B3FC18
21. pc=00A34384 addr=0740EA20
22. pc=00A342C8 addr=08B62D70
23. pc=60000010 addr=08F4BCD8
24. pc=00A343E4 addr=08F4BC70
25. pc=00A34384 addr=08A78570
26. pc=60000014 addr=08B8A8F8
27. pc=00A342C8 addr=08B8A888
28. pc=00A341EC addr=08B61600
29. pc=00A46414 addr=08B77760
30. pc=00A341EC addr=08F2BDC8
31. pc=00A341EC addr=08DF4050
32. pc=00A32FE0 addr=08DF4050
33. pc=2000003C addr=08DF4050
34. pc=00A341EC addr=08DF4050
35. pc=00A32FE0 addr=08B61600
36. pc=2000002C addr=08B61600
37. pc=00A341EC addr=0915A9F0
38. pc=00A3265C addr=08B61600
39. pc=00A32654 addr=06FC9DF8
40. pc=00A341EC addr=08CA5590
41. pc=00A341EC addr=0739E208
42. pc=00A341EC addr=08B05508
43. pc=00A341EC addr=08AC1BF0
44. pc=00A341EC addr=08A5F900
45. pc=00A341EC addr=08A5E370
46. pc=60000010 addr=0741CEC8
47. pc=00A343E4 addr=0741CE60
48. pc=00A34384 addr=08F3F280
49. pc=00A342C8 addr=08BD5950
50. pc=00A3331C addr=08B8A888
51. pc=2000004C addr=08B8A888
52. pc=00A36188 addr=08A78570
53. pc=20000020 addr=08A78570
54. pc=00A33658 addr=08F4BC70
55. pc=20000044 addr=08F4BC70
56. pc=00A32FE0 addr=0915A9F0
57. pc=20000010 addr=0915A9F0
58. pc=00A3331C addr=08BD5950
59. pc=20000044 addr=08BD5950
60. pc=00A15C2C addr=08F3F280
61. pc=2000002C addr=08F3F280
62. pc=00A15944 addr=0741CE60
63. pc=20000044 addr=0741CE60
64. pc=00A32FE0 addr=08CA5590
Does this output say anything?
Based on the current information.
First, the most recent reboot was at 05:08:57 UTC+8 Fri Feb 21 2025, which was rebooted by reload.
Second, earlier, at 02/20/2025 20:24:42, the device crashed.
So, you can still check whether there is crashinfo in the bootflash of your Cat4500 device. If so, you can check the content in crashinfo. Most importantly! When did your device reboot? The time needs to match. The two reboots we have seen so far are a crash on February 20 and a reload command reboot on February 21. Which one is the device failure time?
Thank you for your reply,How can i search bootflash in the show tech-support .txt or i can use which commadn to check it. I'm sorry because I don't have much experience with this.
sorry, Last reset from Reload in the show version output
Well ,In this case, the device was rebooted by a reload operation, which seems to be the expected operation. As mentioned before, if there is AAA audit or log server, you can see who logged in at the corresponding time.
hi,Leo
I'and read your replies to other posts in the morning about C9300." show log on uptime details" this command in C4506 is not supported.
show environment ------------------
no alarm
Chassis Temperature = 30 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-1300ACV AC 1300W good good good
PS2 PWR-C45-1300ACV AC 1300W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Supervisor Led Color : Green
Fantray : Good
Power consumed by Fantray : 50 Watts
Now i only have show tech-support.txt , it has information about dir only this.
------------------ dir nvram: ------------------
Directory of nvram:/
392 -rw- 11041 <no date> startup-config
393 ---- 27 <no date> private-config
1 ---- 4 <no date> rf_cold_starts
2 -rw- 7718 <no date> ifIndex-table
8 ---- 12 <no date> persistent-data
413676 bytes total (392316 bytes free)
Maybe you can search it in the 'show tech' file by issue 'show bootflash:' command
