取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Nexus jumbo packets error
tim20110612
Hello All,
I'm using a circulator to combine 400G Dual LC interfaces into a single LC interface. However, I'm occasionally receiving two jumbo packets. Is this related to the circulator or transceiver (a Layer 1 issue)?
Or is this just a random Layer 2 or Layer 3 issue? (Layer 2 is supposed to be frames, so I assume "packets" should be Layer 3.)
Thank you!
N9K-93600# show interface ethernet 1/35
Ethernet1/35 is up
admin state is up, Dedicated Interface
Hardware: 10000/25000/40000/50000/100000/200000/400000 Ethernet, address: a410
.b62f.1947 (bia a410.b62f.19f8)
Internet Address is 10.1.102.2/24
MTU 1500 bytes, BW 400000000 Kbit , DLY 10 usec
reliability 255/255, txload 62/255, rxload 62/255
Encapsulation ARPA, medium is broadcast
full-duplex, 400 Gb/s, media type is 400G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is Kp-fec
Last link flapped 04:10:40
Last clearing of "show interface" counters 04:07:17
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 98700362224 bits/sec, 8127495 packets/sec
30 seconds output rate 98700366592 bits/sec, 8127495 packets/sec
input rate 98.70 Gbps, 8.13 Mpps; output rate 98.70 Gbps, 8.13 Mpps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 98702380264 bits/sec, 8127591 packets/sec
300 seconds output rate 98702380416 bits/sec, 8127592 packets/sec
RX
120586486816 unicast packets 532 multicast packets 6 broadcast packets
120586487356 input packets 183050287133052 bytes
2 jumbo packets 0 storm suppression bytes
0 runts 2 giants 0 CRC 0 no buffer
2 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
0 Stomped CRC
1 个已接受解答
已接受的解答
Rockyw
Based on the provided interface output and your description, the occasional reception of two jumbo packets is not related to the optical circulator or transceiver (Layer 1). Here's a detailed explanation:
1. Jumbo Packets are a Layer 2 Issue
·Jumbo packets (or jumbo frames) are Ethernet frames exceeding the standard MTU size of 1,500 bytes (typically up to 9,000 bytes). They are Layer 2 constructs (frames), not Layer 3 packets, as they involve frame size violations rather than IP packet issues.
The show interface output shows:
·2 jumbo packets: Frames larger than the configured MTU (1,500 bytes in your output) but within the system's jumbo MTU limit (if enabled).
·2 input errors and 2 giants: These counters align with jumbo frames being discarded as errors due to MTU mismatch or misconfiguration.
2. Optical Circulator is a Passive Component
·The circulator is a passive optical device that directs light unidirectionally (e.g., Port 1 → Port 2, Port 2 → Port 3) but cannot generate, modify, or interpret data frames. It operates purely at the physical layer (Light/Layer 1) and has no awareness of frame sizes or content.
·Similarly, the transceiver (e.g., 400G QSFP-DD) converts electrical signals to optical signals and vice versa but does not create or alter frame sizes. Issues like jumbo frames originate from higher layers.
3. Likely Causes (Layer 2 or Configuration)
·MTU Mismatch: A connected device (e.g., server, storage array) might be sending frames larger than the interface's MTU (1,500 bytes). This is common in environments using jumbo frames for high-throughput applications like storage (iSCSI/NFS) or data backups.
·Misconfigured Jumbo Frame Support: If jumbo frames are partially enabled (e.g., system jumbo MTU set but not applied consistently), oversized frames may be counted as jumbo packets and dropped.
·Software/Hardware Anomaly: Rarely, a brief glitch in NIC drivers, switching ASICs, or FEC (Forward Error Correction) processing could cause frame reassembly errors, leading to oversized frames. However, this is less common than configuration issues.
4. Why It’s Not Random Layer 3
Layer 3 (IP packets) issues would manifest as routing errors, TTL expires, or ACL drops, not jumbo packet counters. The term "packets" in the output is a misnomer; Cisco uses it interchangeably for frames in this context.
Recommended Actions:
1.Check Connected Devices: Verify the MTU configuration on devices linked to this interface. Ensure they are not sending frames >1,500 bytes unless jumbo frames are explicitly configured end-to-end.
2.Validate Jumbo Frame Settings: Use show system mtu to confirm the global jumbo MTU size. If needed, uniformly enable jumbo frames across all relevant interfaces.
3.Monitor Traffic Sources: Use packet captures or show counters to identify the source of oversized frames if the issue persists.
Conclusion: This is a Layer 2/configuration issue, not a Layer 1 hardware fault. The circulator and transceiver are innocent; focus on MTU consistency and endpoint configurations.
Rockyw | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
2 条回复2
Rockyw
Thank you Rockyw,
Your answer is very detailed. I've marked it as the answer.
Are you China?
快捷链接
