取消
显示结果
搜索替代
您的意思是:
公告
December 2020
1300
查看次数
有帮助
回复
zhangsx779542
Beginner
dial-peer voip问题
情景:
公司接了两路电话,通过fxo卡接入PSTN,分别做了aa应用,然后配置了几个dial-peer voip指向call manager地址,其中一个destination-pattern是call manager上CTI路由点,五位号码,另一个destination-pattern是内部分机的路由
问题:
其中有一路电话可正常通过aa应用转入分机或者CTI路由点
另一路只能转分机,转入CTI路由点时嘟嘟声,但是可以通过端口下的connection plar 转入
两路电话在H323网关上的配置如下,有问题的号码为32569695
aa:
service aa flash:samesun.2.0.1.1BO.tcl
param operator 8000
paramspace english index 1
paramspace english language en
paramspace english prefix en
param aa-pilot 32569695
service aa3 flash:its-CISCO.2.0.1.0.tcl
param aa-pilot 62186985
dial-peer:
dial-peer voice 32569695 pots
translation-profile outgoing outgoing
service aa
destination-pattern 9T
incoming called-number 32569695
no digit-strip
port 0/0/0
dial-peer voice 62186985 pots
description to_95594
service aa3
incoming called-number 62186985
no digit-strip
port 0/0/3
dial-peer voice 955 voip
destination-pattern 955..
session target ipv4:192.168.3.163
voice-class codec 1
voice-class h323 1
dtmf-relay cisco-rtp h245-alphanumeric h245-signal rtp-nte
no vad
3 条回复3
zhangsx779542
Beginner
附上debug日志
Dial String=17301820333, Expanded String=17301820333, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Dec 17 11:02:10: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
Dec 17 11:02:10: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 17 11:02:10: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Dec 17 11:02:10: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Calling Number=, Called Number=559, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=559
Dial String=559, Expanded String=559, Calling Number=
Result=-1
Result=NO_MATCH(-1)
zhangsx779542
Beginner
似乎是没有命中到那条dial-peer
liyanazure
Beginner
test命令测试一下这几个dial-peer
Content for Community-Ad
