取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Jabber Guest SDK 可以自定义UI吗?
fuzongsun9384
集成Jabber Guest SDK 可以自定义UI吗?SDK中没有,如果有方法可以自定义,请告知。谢谢
1 条回复1
Rockyw
楼主看过下面的文档吗?
Cisco Jabber Guest SDK Developer Guide :
https://d1nmyq4gcgsfi5.cloudfront.net/site/jabber-guestsdk/documents/android-developer-guide/v11_0_0/
Creating Your Own Custom User Interface
The most flexible approach for using the Jabber Guest SDK is to use the component pieces however you see fit within your own application.
Pros
Full customization of branding and theming within your application
Allows for unique and special-purposed usage within your application interface
Cons
Your application would have to request the required permissions
There is custom code to write
It may not match your application theme
Rockyw | If it solves your problem, please mark as answer. Thanks !
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
