取消
显示结果
搜索替代
您的意思是:
查看次数
30
有帮助
回复
Roomkit 的HDMI EDID参数
sunquan001
What is the HDMI edid parameter for Roomkt?
4 条回复4
Tianjun Zhou
https://www.extron.com/company/article.aspx?id=uedid
EDID data exchange is a standardized means for a display to communicate its capabilities to a source device. The premise of this communications is for the display to relay its operational characteristics, such as its native resolution, to the attached source, and then allow the source to generate the necessary video characteristics to match the needs of the display. This maximizes the functional compatibility between devices without requiring a user to configure them manually, thus reducing the potential for incorrect settings and adjustments that could compromise the quality of the displayed images and overall reliability of the system.
完全感觉
就是给对方全一些标准参数,比如设备名,分辨率之类的
yangkai_716
学习了,thanks a lot for sharing
Rockyw
楼主参考一下
Extended Display Identification Data (EDID) is a metadata format for display devices to describe their capabilities to a video source (e.g. graphics card or set-top box). The data format is defined by a standard published by the Video Electronics Standards Association (VESA).
https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
延伸顯示能力識別(Extended display identification data,簡稱EDID)是指螢幕解析度的資料,包括廠商名稱與序號。一般EDID存在於顯示器的PROM或EEPROM內。一般如要讀取EDID都是透過I2C,slave address是0x50。目前HDMI 1.0 - 1.3c使用EDID結構1.3版。
https://zh.wikipedia.org/zh-hans/EDID
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
