取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
UCSB-B200-M4 报错信息F0637 POWER-CAP-FAIL
qinxq
3 条回复3
fltPowerBudgetPowerBudgetBmcProblem
Fault Code: F0637
Message
Power cap application failed for server [chassisId]/[slotId]Power cap application failed for server [id]
Explanation
This fault typically occurs when the server CIMC or BIOS has failed to enforce the configured power cap.
Recommended Action
If you see this fault, take the following actions:
Step 1blank.gif Check the power consumption of the blade server. If the server is consuming significantly more power than configured in the power cap, switch to a manual per blade cap configuration. If the power consumption is still too high, consider reducing the group cap so that the power consumption of other chassis consumption can be reduced to make up for the increase.
Step 2blank.gif If the power consumption is still too high, the CIMC or BIOS software is likely faulty.
Step 3blank.gif Create a show tech-support file for Cisco UCS Manager and the chassis and then contact Cisco TAC.
Fault Details
Severity: major
Cause: power-cap-fail
mibFaultCode: 637
mibFaultName: fltPowerBudgetPowerBudgetBmcProblem
moClass: power:Budget
Type: environmental
Callhome: none
Auto Cleared: true
Is Implemented: true
Affected MO: sys/chassis-[id]/blade-[slotId]/budget
Affected MO: sys/chassis-[id]/blade-[slotId]/ext-board-[id]/budget
Affected MO: sys/chassis-[id]/budget
Affected MO: sys/chassis-[id]/cartridge-[slotId]/server-[serverInstanceId]/budget
Affected MO: sys/chassis-[id]/cartridge-[slotId]/server-[serverInstanceId]/ext-board-[id]/budget
Affected MO: sys/fex-[id]/budget
Affected MO: sys/rack-unit-[id]/budget
Affected MO: sys/rack-unit-[id]/ext-board-[id]/budget
Affected MO: sys/switch-[id]/budget
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/faults/reference/3-1/UCSFaultsErrorsRef_3-1/UCS_SEMs_3-1.html
参考:
https://community.cisco.com/t5/unified-computing-system/f0637-power-cap-fault/td-p/3403674
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
qinxq
Fault Code: F0637
谢谢指导。
Rockyw
楼主参考一下下面的文档,看看有没有帮助
F0637 Power Cap Fault
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
