取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
仓库里面翻出来一台4006交换机,但是没有密码,请教大神
将仓库里面一台交换机进行了利旧,但是通过console线连接以后,直接提示需要输入密码,直接就是password:,没有密码只能进行硬重置,长按reset10s,重启以后还是需要直接键入password。来请教一下大神,这个是什么情况,是无法重置吗
3 条回复3
huoran1234
这设备都没见过,应该还是运行CatOS的,找到了一篇文档,供参考吧。
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/12043-pswdrec-6000.html
请参考如下内容
Sample Output/Example Procedure
This sample output is the result of the password recovery procedure on a Catalyst 4000 Supervisor Engine III.
c-4006-SUPIII> enable
Password:
Password:
Password:
% Bad secrets
!--- Here, you power cycle the switch.
 * Welcome to ROM Monitor for WS-X4014 System.            *
 * Copyright (c) 1999-2000, 2001 by Cisco Systems, Inc.   *
 * All rights reserved.                                   *
 ROM Monitor Program Version 12.1(10r)EY(1.21)
 Board type 1, Board revision 7
 Swamp FPGA revision 16, Dagobah FPGA revision 43
 Timer interrupt test passed.
 MAC Address  : 00-02-b9-83-af-fe
 IP Address   : 172.16.84.122
 Netmask      : 255.255.255.0
 Gateway      : 172.16.84.1
 TftpServer   : Not set.
 Main Memory  : 256 Mbytes
 ***** The system will autoboot in 5 seconds *****
 Type control-C to prevent autobooting.
!--- At this point, press Ctrl-C.
Autoboot cancelled......... please wait!!!
rommon 1 > [interrupt]
rommon 1 > confreg
 Configuration Summary :
 => load ROM after netboot fails
 => console baud: 9600
 => autoboot from: commands specified in 'BOOT' environment variable
 do you wish to change the configuration? y/n [n]:  y
 enable "diagnostic mode"? y/n [n]:  n
 enable "use net in IP bcast address"? y/n [n]:  n
 disable "load ROM after netboot fails"? y/n [n]:  n
 enable "use all zero broadcast"? y/n [n]:  n
 enable "break/abort has effect"? y/n [n]:  n
 enable "ignore system config info"? y/n [n]:  y
 change console baud rate? y/n [n]:  n
 change the boot characteristics? y/n [n]:  n
 => ignore system config info
 do you wish to save this configuration? y/n [n]:  y
 You must reset or power cycle for new configuration to take effect
rommon 2 > reset
Resetting .......
rommon 3 >
 ******** The system will autoboot now ********
 config-register = 0x2142
 Autobooting using BOOT variable specified file.....
 Current BOOT file is --- bootflash:
Rommon reg: 0x2B004180
Decompressing the image : ###########################
####################################### [OK]
k2diags version 1.6
prod: WS-X4014  part: 73-6854-07  serial: JAB0546060Z
Power-on-self-test for Module 1:  WS-X4014
Status: (. = Pass, F = Fail)
Traffic using serdes loopback (L2; one port at a time)...
switch port 0: .       switch port 1: .       switch port 2: .
switch port 3: .       switch port 4: .       switch port 5: .
switch port 6: .       switch port 7: .       switch port 8: .
!--- Output suppressed.
Module 1 Passed
Exiting to ios...
Rommon reg: 0x2B000180
######################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (TM) Catalyst 4000 L3 Switch Software (cat4000-IS-M),
   Version 12.1(8a)EW,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 24-Jan-02 17:34 by ccai
Image text-base: 0x00000000, database: 0x00AA2B8C
cisco WS-C4006 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX04183666
Last reset from Reload
32 Gigabit Ethernet/IEEE 802.3 interface(s)
467K bytes of nonvolatile configuration memory.
Press RETURN to get started!
00:00:21: %SYS-5-RESTART: System restarted --
00:00:21: %SNMP-5-COLDSTART: SNMP agent on host Switch is undergoing a cold start
Switch> enable
Switch# show version
ROM: 12.1(10r)EY(1.21)
Switch uptime is 5 minutes
System returned to ROM by reload
Running default software
Configuration register is 0x2142
Switch#
Switch#configure memory
Uncompressed configuration from 1307 bytes to 3014 bytes
c-4006-SUPIII#
00:13:52: %SYS-5-CONFIG_I: Configured from memory by console
c-4006-SUPIII#show running-config
Building configuration...
Current configuration : 3014 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname c-4006-SUPIII
boot system flash bootflash:
vtp mode transparent
vlan 20
  private-vlan primary
vlan 100
vlan 202
  private-vlan association 440
vlan 440
  private-vlan isolated
vlan 500
ip subnet-zero
no ip domain-lookup
ip multicast-routing
interface GigabitEthernet1/1
 no switchport
 ip address 10.1.1.1 255.255.255.0
 ip pim dense-mode
interface GigabitEthernet1/2
 no switchport
 ip address 20.1.1.1 255.255.255.0
interface Vlan1
 ip address 172.16.84.140 255.255.255.0
 ip pim dense-mode
interface Vlan2
 no ip address
 shutdown
interface Vlan20
 no ip address
 shutdown
line con 0
 stopbits 1
line vty 0 4
 login
end
c-4006-SUPIII#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
c-4006-SUPIII(config)#no enable secret
!--- This step is necessary if the switch had !--- an enable secret password.
c-4006-SUPIII(config)#enable secret < password >
[Choose a strong password with at least one capital letter,
one number, and one special character.]
c-4006-SUPIII(config)#config-register 0x2102
c-4006-SUPIII(config)#^Z
c-4006-SUPIII#
00:19:01: %SYS-5-CONFIG_I: Configured from console by console
c-4006-SUPIII#write memory
Compressed configuration from 3061 bytes to 1365 bytes[OK]
c-4006-SUPIII#show version
c-4006-SUPIII uptime is 20 minutes
Configuration register is 0x2142 (will be 0x2102 at next reload)
c-4006-SUPIII#
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/21229-pswdrec-cat4000-supiii-21229.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Rockyw
楼主参考一下下面的文档,看看有没有帮助。
Cisco交换机4500/4000密码恢复详细过程
https://blog.csdn.net/u014075470/article/details/80149717
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
