安全讨论区
与安全技术专家互动,发布问题寻求帮助
取消
显示结果
搜索替代
您的意思是:
December 2020
论坛帖子
How to transmit voice, video and other data when using webex in China?1. Directly access webex servers outside China?2. Does Webex also have servers in China? The data that needs to be transmitted must first be forwarded to foreign countries through ...
1360393739 发布者 Level 1
  • 67 查看次数
  • 0 回复
  • 0 有帮助
in ASA,i have enter SSH command :crypto key generate rsa modulus 1024aaa authentication ssh console LOCALssh 172.32.254.0 255.255.255.0 managementssh version 2ssh key-exchange group dh-group1-sha1Yesterday when i configed,i can logined from SSH。and w...
renma19th 发布者 Level 1
  • 310 查看次数
  • 6 回复
  • 0 有帮助
asa防火墙配置AAA认证,并在本地配置逃生账号。使用AAA账号登录无异常。使用逃生账号登录时,有时提示access deny登录失败,有时可以正常登录,无特别的规律。这是什么原因导致的。AAA配置如下: aaa-server TACSRV protocol tacacs+aaa-server TACSRV (INSIDE) host x.x.x.xtimeout 60key *****aaa-server TACSRV (INSIDE) host x.x.x.xtimeout 60key **...
lee-HP 发布者 Level 1
  • 142 查看次数
  • 1 回复
  • 0 有帮助
hello :we are using the anyconnect secure mobility 4.5 while the server is asa5515,it will be upgraded to FRP-ASA-1120.Considering different client software products,My question is if the secure mobility 4.5 can be upgraded to secure client 5.0 autom...
jh.duan 发布者 Level 1
  • 346 查看次数
  • 4 回复
  • 0 有帮助
有两台同型号的ASA 5525-X,使用的是9.8版本,进入配置模式后,很多命令都无法使用,就连接口模式下都不能配置ip地址,几乎是什么都做不了。这样的问题应该怎么解决?请各位大神帮帮忙啊?以下是相关的设备信息:很多的配置命令没有,设备基本当砖头了:ASA5525(config-if)# ?Interface configuration commands: channel-group Etherchannel/port bundling configuration default ...
YI1055640705 发布者 Level 1
  • 4327 查看次数
  • 6 回复
  • 0 有帮助
We are going to upgrade the ASA5515 to FPR-ASA-1120,i am confused about the difference between FPR-NGFW-1120 and FPR-ASA-1120,i want konw how to choose the model according to the specific request.my current request is ssl-vpn function,so i think it i...
jh.duan 发布者 Level 1
  • 255 查看次数
  • 2 回复
  • 0 有帮助
we are using anyconnect 4.5 client software for ASA5512 ,we are going to upgrade the ASA5512 to FRP-ASA1120。i want to konow that if the anyconnect 4.5 client can connect the FRP-ASA1120,because we do not want to upgrade the client software.thank you!...
jh.duan 发布者 Level 1
  • 378 查看次数
  • 4 回复
  • 0 有帮助
故障现象:anyconnect vpn可以正常连接登录,无报错ASA侧查看用户vpn-session 正常,规则正常开通Windows 11系统内使用route print -4 可以查看到路由表正常学习到vpn下发的路由访问目标网址或者ip总是会走电脑的默认路由,而不是优先级更优的vpn下发路由解决方法:卸载用户安装的猎豹wifi软件,重启后再次连接vpn正常访问公司页面
Cheven 发布者 Spotlight
  • 248 查看次数
  • 2 回复
  • 1 有帮助
我們公司的C2960系列交換機(型號WS-C2960-24TT-L、WS-C2960+24TC-L)近期在使用Nessus弱點掃描時發現有以下兩個High弱點,大致指向的是SHA-1的加密證書導致的弱點。SW Version為15.0(2)SE11和15.2(2)E7,請問要如何解決以下两个弱點,是否需要升級交換機ISO到哪個版本,有嘗試將交換機自帶的證書刪除,但重新掃描還是會有弱點。報錯信息:1. SSL Certificate Signed Using Weak Hashing Algori...
VergilJin 发布者 Level 1
  • 391 查看次数
  • 2 回复
  • 0 有帮助
早安大家,其实802.1x个跟AAA最大区别是什么啊,有点困惑!如果用无线wireless, 跟有线wired 连接网络,那么验证会有很大的区别吗?关于802.1x & AAA@wireless @Wired
lucaslee05 发布者 Spotlight
  • 352 查看次数
  • 2 回复
  • 0 有帮助
nat (inside,outside) source static inside-net inside-net-tr object-group network inside-net  network-object host 192.168.1.1  network-object host 192.168.1.2  network-object host 192.168.1.3object-group network inside-net-tr  network-object host 172....
xdy_ch 发布者 Level 1
  • 362 查看次数
  • 3 回复
  • 0 有帮助
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
待解决问题
问答专家排行榜
