取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
11
回复
anyconnect无法支持AAA认证
xiaotongse
PC在互联网上,PC通过防火墙ASA下载anyconnect3.1,下载通过anyconnect拨号后发现,仅支持本地用户名和密码拨号IKEV2,不支持通过LDAP拨号;
配置:
int g0
nameif Inside
no shut
int g1
ip address 202.16.1.1 255.255.255.252
nameif Outside
no shut
access-list icmp extended peremit icmp any any
access-list icmp extended permit udp any any
access-group icmp in interface Outside
object network LAN
sub 172.16.1.0 255.255.255.0
nat (Inside,Outside) dy inter
object network Remote
sub 10.144.1.0 255.255.255.0
nat (Inside,outside) source static LAN LAN destination static Remote Remote
ip local pool ezvpn 10.144.1.11-10.144.1.20
domain-name test.org
clock timezone GMT +8
ntp server 192.168.1.2
crypto ca trust-point CA
enrollment url http://202.16.1.2:80
sub-name cn=asa.test.org
fqdn asa.test.org
crypto ca authe CA
crypto ca enroll CA
http server enable 500
http 0 0 outside
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-3.1.14018-k9.pkg
anyconnect enable
anyconnect profiles group1 disk0:/group1.xml
group-policy group1-certenroll internal
group-policy group1-certenroll attributes
vpn-tunnel-protocol ssl-client
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split
address-pools value ezvpn
webvpn
anyconnect profiles value group1 type user
username cisco password cisco
username cisco attribute
vpn-tunnel-group group1-certenroll
ssl trust-point CA
crypto ikev2 enable outside
crypto ikev2 remote-access trust-point CA
crypto ikev2 policy 1
group 2
integrity sha
lifetime 43200
prf sha
crypto ipsec ikev2 ipsec-proposal FirstSet
protocol esp encryption 3des aes
crypto dynamic-map dyn1 1 set ikev2 ipsec-proposal FirstSet
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
tunnel-group test type remote-access
tunnel-group test gen
authentication-server-group ldap LOCAL
ldap attribute-map group-to-policy
map-name memberOf IETF-Radius-Class
map-value memberOf CN=group1,OU=Depart1,DC=test,DC=org
aaa-server 2008 (Inside) host 10.1.1.1
ldap-attribute-map group-to-policy
ldap-base-dn dc=test, dc=org
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password 1a.cisco
ldap-login-dn cn=administrator, cn=users, dc=test, dc=org group1-certenroll
server-type microsoft
11 条回复11
xiaotongse
authentication-server-group 2008 LOCAL
one-time
Level 13
Level 13
authentication-server-group 2008 LOCA ...
感谢您的提问!稍后会有小伙伴为您解答的!:)
13nash
Level 8
Level 8
LDAP测试通讯正常吗
xiaotongse
LDAP测试没有任何问题,从asa通过test测试正常的
fortune
是支持的哦,我上次才做过配置,你可以谷歌一下ASA ldap authe 就有案例
ilay
1、你看下log里面 aaa-server 有没有fail 的记录,如果有的话可以尝试重新标记aaa-server为active
命令示例:aaa-server SrvName active host 192.168.12.x
2、如果aaa-server是active的,你可以先连接anyconnect ,然后通过show vpn-sessiondb anyconnect 查看拨入用户的tunnel-group ,如果 Tunnel Group和你定义的tunnel名不一致,那么最好检查一下是否启用了tunnel-group-list enable
启用tunnel group部分配置如下
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-3.1.05187-k9.pkg 1
anyconnect enable
tunnel-group SSLVPN type remote-access
tunnel-group SSLVPN general-attributes
address-pool vpn_pool
authentication-server-group LDAP_Srv LOCAL
default-group-policy SSLVPN
tunnel-group SSLVPN webvpn-attributes
group-alias sslvpn enable
show vpn-sessiondb anyconnect 输出如下
SSLVPN# sh vpn-sessiondb anyconnect
Session Type: AnyConnect
Username : vpnuser Index : 24
Assigned IP : 10.x.x.x Public IP : 100.100.100.100
Protocol : AnyConnect-Parent SSL-Tunnel
License : AnyConnect Premium
Encryption : AnyConnect-Parent: (1)none SSL-Tunnel: (1)AES128
Hashing : AnyConnect-Parent: (1)none SSL-Tunnel: (1)SHA1
Bytes Tx : 821187 Bytes Rx : 755243
Group Policy : SSLVPN Tunnel Group : SSLVPN
Login Time : 19:04:29 UTC Sun Mar 26 2017
Duration : 6h:49m:52s
Inactivity : 0h:00m:00s
VLAN Mapping : N/A VLAN : none
Audt Sess ID : c0a801010001800058d810bd
Security Grp : none
SSLVPN#
jingjian
1.NAT配置错误,nat (Inside,outside) source static LAN LAN destination static Remote Remote,G1的接口命名为Outside,nat配置的为小写outside.
2.后续的涉及到outside的调用全部是小写, 所以很多地方的调用都是错误的。
3.
建议可以把username cisco tunnel-group 调用配置删除,更换为调用vpn-group-policy group1-certenroll ,然后在tunnel-group 下调用group-policy
default-group-policy group1-certenroll
这样调用的策略就一致了,就不存策略调用先后的问题
另外你调用ldap也是错误的,定义的aaa-server 2008, 调用的时候变成ldap
xiaotongse
此问题目前已经解决,我调用默认的DefaultWEBGroup策略就没有任何问题
Yanli Sun
Community Manager
Community Manager
感谢分享解决方案
xiaotongse
不过还是要谢谢大家的帮助
one-time
Level 13
Level 13
xiaotongse 发表于 2017-3-28 17:02
不过还是要谢谢大家的帮助
请记得标注最佳答案哈~
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
