取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
ASA 的配置问题
haifengmiao9768
求指教
ASA 能ping通R15 但是 用内部的vpc就不行
ASA 代码
ASA Version 8.4(2)
hostname ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
nameif inside1
security-level 100
ip address 192.168.150.2 255.255.255.0
ospf message-digest-key 1 md5 *****
ospf authentication message-digest
interface Ethernet1
nameif inside2
security-level 100
ip address 192.168.160.2 255.255.255.0
interface Ethernet2
nameif outside1
security-level 0
ip address 100.100.1.2 255.255.255.0
interface Ethernet3
nameif outside2
security-level 0
ip address 200.200.1.2 255.255.255.0
ftp mode passive
object network in-ips1
subnet 192.168.10.0 255.255.255.0
access-list 100 extended permit ip any any
access-list 100 extended permit icmp any any
pager lines 24
mtu outside1 1500
mtu outside2 1500
mtu inside1 1500
mtu inside2 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649-103.bin
no asdm history enable
arp timeout 14400
nat (inside1,outside1) dynamic interface
access-group 100 in interface outside1
router ospf 1
router-id 5.5.5.5
network 100.100.1.0 255.255.255.0 area 1
network 192.168.150.0 255.255.255.0 area 0
network 192.168.160.0 255.255.255.0 area 0
network 200.200.1.0 255.255.255.0 area 1
log-adj-changes
default-information originate
route outside1 0.0.0.0 0.0.0.0 100.100.1.1 1 track 1
5 条回复5
haifengmiao9768
:Q:Q:Q:Q:Q:Q:Q:Q:Q:Q
haifengmiao9768
:Q:Q:Q:Q:Q:Q:Q:Q:Q:Q:Q:Q
liu_zhimin
跟踪路径看下
ilay
如果配置检查没啥问题的话,可以尝试吧交换机的cef关掉,eve模拟的交换机,在某些情况下是有bug的
rainboy999
inside也允许ICMP出去,做个ACL试试
快捷链接
