取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
ASA 5506-X 一通电STATUS 桔红灯一闪一闪
xiaozizheng
接console 连接超级终端无任何提示,进不了
请教大家什么问题?硬件坏了吗?
5 条回复5
Status
System operating status:
Green—Normal system function.
Amber—Critical alarm indicating one or more of the following:
Major failure of a hardware or software component.
Over-temperature condition.
Power voltage outside the tolerance range.
https://www.cisco.com/c/en/us/td/docs/security/asa/hw/maintenance/5506xguide/b_Install_Guide_5506/b_Install_Guide_5506_chapter_01.html#concept_9EB479BF65B64360A7BF8DD21F3DD6C9
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Rockyw
通过其他方式能不能访问?
Rockyw | If it solves your problem, please mark as answer. Thanks !
console 也不行,就基本没戏了。
关键是他这台设备是旧设备还是新设备。
无论新旧,如果确认console没反应了,基本上不是软件层级、配置方面靠自己能修复的,在维保内就RMA呗,旧设备就是找第三方维修了
快捷链接
