取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
cisco SSL vpn连接老是掉线,什么问题?
lsy18772306122
提示1. The secure gateway has terminated the VPN connection .the following message was received from the secure gateway: Idle Timeout.
2.
The VPN connetion was started by a remote desktop user whose remote console has been disconnected . It is presumed the VPN routing configuration is responsible for the remote console disconnect .The VPN connetion has been disconnected to allow the remote console to conect again. A remote desktop user must wait 90 seconds after VPN establishment before disconnecting the remote console to avoid this condition .
有什么解决办法?求解
能保存密码吗?设置自动重连吗?
1 个已接受解答
已接受的解答
pebao
是只有一个client掉线还是所有client都掉线啊,从您贴出来的信息是IDLE time超时,到ASA上更改IDLE timeout时间再观察。
在原帖中查看解决方案
6 条回复6
pebao
taosun2
Verify Idle/Session Timeout
If the idle timeout is set to 30 minutes (default), it means that it drops the tunnel after 30 minutes of no traffic passes through it. The VPN client gets disconnected after 30 minutes regardless of the setting of idle timeout and encounters the PEER_DELETE-IKE_DELETE_UNSPECIFIED error.
Configure idle timeout and session timeout as none in order to make the tunnel always up, and so that the tunnel is never dropped even when using third party devices.
taosun2
gang liu
IDLE timeout的问题,不能自动保存密码(无此选项),自动重连是缺省配置。
one-time
Level 13
Level 13
xz7680170z 发表于 2016-3-15 14:11 back.gif
感谢您的回复哦!
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
