Easyvpn拨入成功后,可以正常访问内网资源,但是却无法访问防火墙和下连桥接的深信服AC,请大神帮忙检查一下。
PVSZ-FW# show run
: Saved
: Hardware: ASA5516, 8192 MB RAM, CPU Atom C2000 series 2416 MHz, 1 CPU (8 cores)
ASA Version 9.8(2)
hostname PVSZ-FW
enable password $sha512$5000$Fk1JnccNsuAkCBo0jWYwOQ==$1jf0+tgn1akW9Gsv3LbJGg== pbkdf2
names
ip local pool ezvpn 10.10.100.100-10.10.100.200 mask 255.255.255.0
interface GigabitEthernet1/1
description link-to-ISP
nameif outside
security-level 0
ip address 202.100.100.6 255.255.255.252
interface GigabitEthernet1/2
description link-to-Sangfor
nameif inside
security-level 100
ip address 10.10.1.1 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network PAT
subnet 0.0.0.0 0.0.0.0
object network vpnnet
subnet 10.10.100.0 255.255.255.0
object network vpn-1
subnet 10.10.1.0 255.255.255.0
object network server
host 10.10.30.10
object-group network SZ
network-object 10.10.30.0 255.255.255.0
network-object 10.10.40.0 255.255.255.0
access-list out extended permit icmp any any
access-list out extended permit ip 10.10.100.0 255.255.255.0 any
access-list out extended permit tcp any interface outside eq www
access-list out extended permit tcp any host 10.10.30.10 eq www
access-list out extended permit tcp any host 202.100.100.6 eq www
access-list out extended permit ip any any
access-list out extended permit tcp any host 10.10.30.10 eq 8888
access-list out extended permit tcp any interface outside eq 8888
access-list split extended permit ip 10.10.30.0 255.255.255.0 any
access-list split extended permit ip 10.10.40.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside,outside) source static SZ SZ destination static vpnnet vpnnet
object network PAT
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp www 8888
access-group out in interface outside
route outside 0.0.0.0 0.0.0.0 202.100.100.5 1
route inside 10.10.10.0 255.255.255.0 10.10.1.2 1
route inside 10.10.20.0 255.255.255.0 10.10.1.2 1
route inside 10.10.30.0 255.255.255.0 10.10.1.2 1
route inside 10.10.40.0 255.255.255.0 10.10.1.2 1
route inside 192.168.111.0 255.255.255.0 10.10.1.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
no aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec ikev1 transform-set cisco esp-3des esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map dymap 10 set ikev1 transform-set cisco
crypto map cisco 10 ipsec-isakmp dynamic dymap
crypto map cisco interface outside
crypto ikev1 enable outside
crypto ikev1 policy 5
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy _split internal
group-policy _split attributes
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
address-pools value ezvpn
dynamic-access-policy-record DfltAccessPolicy
username Tanlin password $sha512$5000$Y7/S5GLFUruARuAFoC5hyw==$DXWXX6GjD/9gC8CtIQItSQ== pbkdf2 privilege 0
username Tanlin attributes
vpn-group-policy _split
password-storage enable
tunnel-group PVSZ type remote-access
tunnel-group PVSZ general-attributes
address-pool ezvpn
default-group-policy _split
authorization-required
tunnel-group PVSZ ipsec-attributes
ikev1 pre-shared-key *****
