取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
有关nexus 5675up-16g and 5696q 最大可支持FC授权数问题
huang.cisco
有关nexus 5675up-16g和 5696q支持最大FC端口问题?
1.5675up-16g可以配置6个12端口授权,总计72端口FC授权。是否是可以自带的24口(16G)+2个2348UPQ(每台24端口FC 16G)=72?
2.N5K-C5696Q可以配置4个20端口授权,总计80个授权。是否可以支持更多的FC端口,假如使用2348UPQ的同时。
About cisco nexus 5675up-16g and 5696q max Fibre Channel (FC) license questionSoft version:NX-OS Release 7.3(0)N1(1) or later
Qutestion 1:
Cisco Nexus 5672UP-16G have max 24 port for Fibre Channel 16G/8G onbord,but it can use 6 of N56-12P-SSK9 licens.so max fc port is 72.
Is it like this :5672UP-16G use fex over FCOE connecte one(only one ) Cisco Nexus 2348UPQ for 72 Fibre Channel (FC) port ?(24+48=72)?
Cisco Nexus 2348UPQ have max 24 port for 16g fibre channel, max 48 port for 8g fibre channel;
if i want to active 72 port 16g fibre channel, i can use one 5672UP-16G and two nexus 2348UPQ? (24+24+24)
Question 2:
N5K-C5696Q have max 8 of N5696-M20UP card,but only max 4 of N56-20PP-SSK9 license .for 8G Fibre Channel (FC),so max FC port is 80.
is it like this: N5K-C5696Q only supporty 80 port of Fibre Channel (FC) if only use onbord N5696-M20UP card;
or
if we use FEX over FCOE connect with Cisco Nexus 2348UPQ ,we can support more Fibre Channel (FC) port ?
like use N5696-M20UP card and N5696-M12Q card, with Cisco Nexus 2348UPQ
i can not find more inforemation Used to verify.
thank you very much
https://supportforums.cisco.com/discussion/13318231/about-cisco-nexus-5675up-16g-and-5696q-max-fibre-channel-fc-license-question
1 个已接受解答
已接受的解答
jingjian
思科5600系列交换机支持FC和FCOE两种存储协议,都是通过store license激活。
但是5672UP-16G,只有16个Unified Ports(统一端口),只有这16个端口可以支持FC,FCOE,Ethernet,剩下的56个端口只能支持FCOE和Ethernet。所以5672UP-16G可以支持72个store license,但是只能支持16个FC接口。
5696Q 比较特殊一些,可以支持两种扩展板卡,LEM 和ULEM, LEM 只支持FCOE和Ethernet, ULEM可以支持FC,FCOE,Ethernet,所以可以支持的FC的数量需要看扩展模块的类型和数量。
FC和FCOE都是通过Store license激活,不可把两者弄混
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5624q-switch/datasheet-c78-733100.html
在原帖中查看解决方案
2 条回复2
jingjian
one-time
Level 13
Level 13
感谢您的提问,期待小伙伴的回复~
快捷链接
