取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Nexus 5000升级
TriAngel
链接:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/upgrade/738_N1_1/n5600_upgrade_downgrade_738_n1_1.html#12771
我这里的环境是Nexus 56128P+N2K-C2348TQ-10GE。现在想对N5K的版本进行升级,目标版本是7.3(8)N1(1),我当前版本到目标版本没有过渡版本已经确认。
我在看升级文档时候发现有ISSU、Disruptive Installation Process、Forcing an Upgrade三种升级方式?但是又感觉哪里不对,N5K升级我理解下来是ISSU不间断升级和间断升级,现在我无法确定Disruptive Installation Process和Forcing an Upgrade关系?
有人能给我讲解下上边三个升级方式的区别吗?
CCIE #62933
1 个已接受解答
已接受的解答
In-Service Software Upgrades(ISSU):In a Nexus series chassis with dual supervisors, you can use the in-service software upgrade (ISSU) feature to upgrade the system software while the system continues to forward traffic. An ISSU uses the existing features of nonstop forwarding (NSF) with stateful switchover (SSO) to perform the software upgrade with no system downtime.
Support for an ISSU on Cisco Nexus 5000 Series switches and Cisco Nexus 2000 Series Fabric Extenders was added with the 4.2(1)N1(1) NX-OS software release.
Disruptive Installation Process:If the conditions required for an ISSU are not met or if you intend to downgrade the software version, the installation process is disruptive. For example, the Cisco Nexus device and any connected FEXs are rebooted, which causes a disruption.
Forcing an Upgrade:You can choose to do a disruptive upgrade if one of the ISSU conditions are not met. One additional reason where you might choose to do a disruptive upgrade is when FEXs are upgraded in a rolling fashion (one FEX at a time), which requires a longer maintenance window. With a disruptive upgrade, all the connected FEXs are upgraded simultaneously, so the maintenance window can be shorter. If you need a shorter maintenance window (with traffic disruption), you can force a disruptive upgrade even if an ISSU can be leveraged. It is important to note the possibility of an outage if you do a disruptive upgrade.
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
3 条回复3
Nexus switch upgrades offer two methods:
1. ISSU
2. Forcing an Upgrade
ISSU provides an uninterrupted upgrade process, and Forcing an Upgrade will cause network interruptions.
If the ISSU upgrade process fails, it will become the Disruptive Installation Process destructive state. If you need to use the Disruptive Installation Process to upgrade, you need to refer to the Forcing an Upgrade upgrade method.
Is my understanding correct?
CCIE #62933
For FEX configurations, prior to the downgrade, the configuration must be converted (if not already used) to use FEX pre-provisioning configuration.
What does this sentence mean?
CCIE #62933
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
