取消
显示结果
搜索替代
您的意思是:
查看次数
6
有帮助
回复
UCS服务器网络问题,寻求大神解答
孙先生
小白一个,第一次操作,寻求大神相助!我的服务器三个刀片服务器的管理IP地址ping不通了,
这是刀片报错日志
Server 1/1 (service profile: ) discovery: failed
[FSM:STAGE:RETRY:]: getting inventory of server 1/1 via CIMC(FSM-STAGE:sam:dme:ComputeBladeDiscover:BmcInventory)
[FSM:STAGE:REMOTE-ERROR]: Result: end-point-unavailable Code: unspecified Message: no connection to MC endpoint(sam:dme:ComputeBladeDiscover:BmcInventory)
[FSM:FAILED]: blade discovery 1/1(FSM:sam:dme:ComputeBladeDiscover)
Server 1/1 (no profile) inaccessible
求大神相助,如何解决这个问题?
4 条回复4
zhengwei272
看看FI接口是不是出问题 看看equipment下chassis里面chassis是不是正常
Rockyw
fsmStFailComputeBladeDiscover:BmcInventory
Fault Code: F16520
Message
[FSM:STAGE:FAILED|RETRY]: getting inventory of server [chassisId]/[slotId] via CIMC(FSM-STAGE:sam:dme:ComputeBladeDiscover:BmcInventory)
Explanation
None set.
Recommended Action
Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. If you cannot resolve the issue, create a show tech-support file and contact Cisco Technical Support.
Fault Details
Severity: warning
Cause: bmc-inventory-failed
mibFaultCode: 16520
mibFaultName: fsmStFailComputeBladeDiscoverBmcInventory
moClass: compute:Blade
Type: fsm
Callhome: none
Auto Cleared: true
Is Implemented: true
Affected MO: sys/chassis-[id]/blade-[slotId]
信息来源:
Cisco FXOS Faults and Error Messages, 1.1(1)
https://www.cisco.com/c/en/us/td/docs/security/firepower/9300/faults/reference/FirepowerFaultsErrorsRef_1-1-1/Firepower_FSMs_1-1-1.html
看来是要找思科帮你解决了。
Rockyw | If it solves your problem, please mark as answer. Thanks !
孙先生
机箱正常啊
孙先生
wifi~ 发表于 2018-4-3 17:03
机箱正常啊
我现在是电脑能ping通刀片的IP地址,但是在刀片里面ping网关就通不了,所以用vmvare登陆不上去
这是什么原因那,一直没想明白
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
