取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
AIR-SAP2602I-C-K9 瘦AP 如何关闭 LED灯啊
hbczjzc
Cisco-AP-2602N#led flash disable 这条命令执行完 ,蓝颜色状态灯 还是常亮啊
6 条回复6
liyanazure
Cisco_CAP3702i#config t
Cisco_CAP3702i(config)#led display ?
dim Turn LED display dim.
off Turn LED display off.
Cisco_CAP3702i(config)#led display off
瘦ap在控制器上关啊,在ap那里可以关。
suzhouxiaoniu
SAP这个不是胖AP吗。我记得CAP的外置天线是廋AP吧,不知道是否记错
Rockyw
在控制器上登陆后,
1、在上方的导航栏选择“Wireless”;
2、在左方的栏目选择“All APs”;
3、选择你希望关闭LED指示灯的AP;
4、选择“advanced”;
5、LED State 打勾,选择“Disabled”;
6、Apply 应用;
7、“Save Configuration”
Rockyw | If it solves your problem, please mark as answer. Thanks !
Rockyw
config ap led-state
To enable or disable the LED-State for an access point, or to configure the flashing of LEDs, use the config ap led-state command.
config ap led-state { enable | disable} { cisco_ap | all}
config ap led-state flash { seconds | indefinite | disable} { cisco_ap | dual-band}
Syntax Description
enable Enables the access point’s LED state.
disable Disables the access point’s LED state.
cisco_ap Name of a Cisco lightweight access point.
flash Configure the flashing of LEDs for an access point.
seconds Duration that the LEDs have to flash. The range is from 1 to 3600 seconds.
indefinite Configures indefinite flashing of the access point’s LED.
dual-band Configures the LED state for all dual-band access points.
sufee
快捷链接
