取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
CAP2702I-H-K9胖AP转成瘦AP
idc000002
Beginner
Beginner
CAP2702I-H-K9胖AP转成瘦AP,从官网下载的ap3g2-rcvk9w8-tar使用命令archive download-sw /force-reload /overwrite tftp://location/image-name,AP会报错"ERROR: Image is not a valid IOS image archive"
破案了,是我通过命令行tftp put镜像文件时,模式不对,选择了accii,应该使用libary模式。
2 条回复2
ilay
Collaborator
Collaborator
1.对比一下文件的hash,确认文件是否被损坏(tar文件无需解压)
2. 尝试使用ap3g2-k9w8的镜像进行测试(rcv的镜像应该在flash中默认存在)
3. 如果确认flash中确认存在recovery的镜像,可以将rcv的镜像设置为首选启动,或者将胖ap的镜像目录直接删除,启动的时候直接会加载rcv镜像。(如果删除k9w7镜像,同时rcv镜像有问题的话,只能使用mode按键进行系统恢复了)
附:删除主镜像后使用rcv镜像的启动过程
IOS Bootloader - Starting system.
flash is writable
Antigua Board
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 19 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 7527936
flashfs[0]: Bytes available: 33630720
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 00:2c:c8:62:22:ec
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-mx.153-3.JK3"...flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-mx.153-3.JK3: no such file or directory
Error loading "flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-mx.153-3.JK3"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Antigua Board Pre-Pilot
40MB format
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 1 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-xx.153-3.JK3;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-xx.153-3.JK3"...flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-xx.153-3.JK3: no such file or directory
Error loading "flash:/ap3g2-k9w8-mx.153-3.JK3/ap3g2-k9w8-xx.153-3.JK3"
Unable to locate IOS image with name **xx**.
Boot CMD: 'flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...############################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JD, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 29-Jul-16 04:10 by prod_rel_team
40MB format
Rockyw
Advisor
Advisor
感谢楼主分享经验,建议在标题上加上【已解决】,以便遇到类似问题网友可以参考。
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
