version 12.4
no service pad
service password-encryption
hostname northsoarAP
logging rate-limit console 9
enable secret 5 $1$e3uG$pCGxihLd2DzFdHv9mKSNF1
no aaa new-model
dot11 syslog
dot11 vlan-name VLAN1 vlan 1
dot11 vlan-name VLAN10 vlan 10
dot11 vlan-name VLAN2 vlan 2
dot11 vlan-name VLAN3 vlan 3
dot11 ssid northsoar16
vlan 1
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 0317540A145A701A1850405747
dot11 ssid northsoar_GUEST
vlan 3
authentication open
mbssid guest-mode
wpa-psk ascii 7 0608003358461A160405
username Cisco password 7 0802455D0A16
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 16 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
ssid northsoar16
mbssid
channel 2437
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.10
no ip route-cache
bridge-group 10
interface BVI1
ip address 172.16.16.200 255.255.255.0
no ip route-cache
ip default-gateway 172.16.16.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eagbridge 1 route ip
line con 0
line vty 0 4
login local
