取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
AIR-CAP702I-C-K9
ooopps201406
咨询下,AIR-CAP702I-C-K9   瘦AP 最大带机量是多少?
5 条回复5
Leo Laohoo
I have a 3700 with >100 wireless clients per day.  No complaints.
我想这个信息是你需要的:
Additional technical specifications include:
  • Support for Cisco Radio Resource Management (RRM)
  • Maximum number of clients per AP = 200
  • Support for Cisco Band Select
  • Support for VideoStream and Adaptive wIPS
  • Rogue AP detection support
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-6/702WAccessPointDG/CiscoAironetSeries_702w_AP_DG.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
ilay
cap702i和 cap1142应该是同一个时代的产品,1142在正常环境里面每个ap大概可以有30个在线终端,当然这个是单5G频段的终端数量,2.4G频段在办公区的使用体验很差,基本放弃了。
cap702i的性能比cap1142还要稍差一点,估计能有20多个终端的连接数量,如果加上2.4G频段可以再往上加一点。
理论上200的带机量基本上不太可能达到
Leo Laohoo
1142 can support >100 wireless clients and is far more superior (hardware wise) than the 2700/3700.
Unlike the build and design quality of the radios of the 2700/3700, the 1142 radios can last a long time before failing.
The firmware of the 1142 is also more stable than the the firmware for the 2700/3700.
Perhaps you are right.
In our office environment, the CAP1142 has indeed been used for a long time.
The number of AP connections is based on previous data (this data is only for the 5G band). For my office environment, supporting over 30 terminals (on the 5G band) is not a problem at all.
Being able to support over 100 clients and ensuring stable use for over 100 clients are two different issues.
From my personal perspective, I do not believe that connecting over 100 clients with the 1142 is a feasible solution under actual conditions.
快捷链接
