取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
8
回复
AIR-SAP16002I 胖AP单点不能上网
jackzhang1847
AIR-SAP16002I 胖AP单点设置,设置后连线无线终点不能上网配置如下:
! Last configuration change at 00:22:07 UTC Mon Mar 1 1993
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$Hqjm$7B25fBJMGmGiQdrq.Jwv3/
no aaa new-model
no ip source-route
no ip cef
ip dhcp excluded-address 192.168.200.10
ip dhcp excluded-address 192.168.200.200
ip dhcp pool wlan
network 192.168.200.0 255.255.255.0default-router 192.168.200.251 255.255.255.0
dns-server 202.96.128.166
lease 0 8
dot11 pause-time 100
dot11 syslog
dot11 ssid CENTERT
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 0157230A4804120E011E1E5841
no ipv6 cef
username Cisco privilege 15 password 7 1012552E2A363B3C23290B79767E6D6B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid CENTER
antenna gain 0
stbc
beamform ofdm
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid CENTER
antenna gain 0
stbc
beamform ofdm
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 885a.92bb.b347
ip address 192.168.200.251 255.255.255.0
no ip route-cache
ip default-gateway 192.168.200.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
请大神帮忙分析一下是哪里配置有问题
1 个已接受解答
已接受的解答
cisco.feng
AP just AP.
无路由功能
用路由器的DHCP即可
在原帖中查看解决方案
8 条回复8
cisco.feng
AP just AP.
无路由功能
用路由器的DHCP即可
Rockyw
终端不能上网提示什么错误?
Rockyw | If it solves your problem, please mark as answer. Thanks !
jingjian
终端默认网关配置错误
ip dhcp pool wlan
因为你设置的网关为:192.168.200.1,所以你的DHCP地址池的default-router需要更改为192.168.200.1
18653465190
为什么一个网关设置成192.168.200.1,一个网关设置成为192.168.200.251????
jackzhang1847
cisco.feng 发表于 2019-2-25 21:37
AP just AP.
无路由功能
用路由器的DHCP即可
谢谢楼主的回复确实是单点胖AP没有路由功能所以客户端可以获取IP地址就是不能上网。
one-time
Level 13
Level 13
如果楼主问题已解决,记得标注最佳答案哦,也是对热心解答的小伙伴们的认可。最佳答案按钮在回复贴的右下角哦~
:handshake感谢各位专家解答,谢谢!
jackzhang1847
管理员 发表于 2019-3-1 14:14
如果楼主问题已解决,记得标注最佳答案哦,也是对热心解答的小伙伴们的认可。最佳答案按钮在回复贴 ...
好的版主,谢谢
one-time
Level 13
Level 13
jackzhang1847 发表于 2019-3-1 16:00
好的版主,谢谢
谢谢楼主~
快捷链接
