取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
AP 9115 memory OID from WLC 9800
Wei Ting Lin
Can the WLC provide the OID of the memory of the collapsed AP?
My WLC9800 version is 17.3.7
3 条回复3
 Do the download of 9800 MIB and open with a MIB Reader . Then search on the MIB Reader for memory.
 Might be there.
监控思科AP9115内存的OID是1.3.6.1.4.1.9.9.48.1.1.1.5,它对应的MIB对象是ciscoMemoryPoolUsed。此外,您还可以通过以下OID来监控AP 9115的内存:
  • 总内存:1.3.6.1.4.1.9.9.48.1.1.1.6(ciscoMemoryPoolLargestFree)
  • 可用内存:1.3.6.1.4.1.9.9.48.1.1.1.6(ciscoMemoryPoolFree)
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
My WLC has managed AP 9115, Whether to set SNMP  through WLC or directly from AP?
I have set SNMP from WLC, but it still doesn't work.
It seems that it is still impossible to read the memory and CPU usage of each AP through SNMP.
快捷链接
