Wcpd always has problems, and then it keeps getting stuck in the following interface. This may be a hardware problem, if there is more information, you can provide it.
ERROR:
/usr/sbin/capwapd: opening /click/wdog_helper/ap_monproc_capwapd failed!: No such file or direcotry
/usr/sbin/capwapd: reading file /click/srcr2/gw/is_gateway: No such file or directory
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
