C1whaitao 发表于 2015-1-30 15:48
麻烦你进入WLC的命令行模式,通过debug client ***(无线客户端网卡MAC) ,查看log 后获知故障的原因,再来解 ...
下面是debug了一次掉线的过程
*pemReceiveTask: Feb 27 02:09:46.785: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
MAC: 14:E6:E4:1C:B3:26 , Binding to Data Plane. SUCCESS !!
*apfMsConnTask_7: Feb 27 02:17:01.625: Association request from the P2P Client Process P2P Ie and Upadte CB
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Replacing Fast Path rule
type = Airespace AP Client
on AP c0:25:5c:a2:a7:70, slot 0, interface = 1, QOS = 2
IPv4 ACL ID = 255, IPv6 ACL ID
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
0, TokenID = 15206 Local Bridging Vlan = 2, Local Bridging intf id = 12
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
255, IPv6 ACL ID 255)
*dtlArpTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 Assigning Address 172.16.1.165 to mobile
*pemReceiveTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 172.16.1.165 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:17:33.073: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:17:55.263: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 Assigning Address 172.16.2.127 to mobile
*pemReceiveTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 172.16.2.127 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:17:55.264: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:17:56.206: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:17:56.206: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:17:56.206: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:17:56.206: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:17:56.207: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:17:56.207: 14:e6:e4:1c:b3:26 Assigning Address 172.16.1.165 to mobile
*pemReceiveTask: Feb 27 02:17:56.207: 14:e6:e4:1c:b3:26 172.16.1.165 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:17:56.207: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 Assigning Address 172.16.2.127 to mobile
*pemReceiveTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 172.16.2.127 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:18:08.627: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:18:11.562: 14:e6:e4:1c:b3:26 Assigning Address 172.16.1.165 to mobile
*pemReceiveTask: Feb 27 02:18:11.563: 14:e6:e4:1c:b3:26 172.16.1.165 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:18:11.563: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 172.16.2.127 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:18:27.227: 14:e6:e4:1c:b3:26 Assigning Address 172.16.2.127 to mobile
*pemReceiveTask: Feb 27 02:18:27.228: 14:e6:e4:1c:b3:26 172.16.2.127 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:18:27.228: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) DHCP Address Re-established
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Reached PLUMBFASTPATH: from line 6873
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Replacing Fast Path rule
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*dtlArpTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 Assigning Address 172.16.1.165 to mobile
*pemReceiveTask: Feb 27 02:18:27.921: 14:e6:e4:1c:b3:26 172.16.1.165 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 27 02:18:27.922: 14:e6:e4:1c:b3:26 Pushing IPv6: fe80:0000:0000:0000: 6c4c:b3e6:0379:a1d4 , and
