取消
显示结果
搜索替代
您的意思是:
查看次数
38
有帮助
评论
ywanxin
在做CPU突高的时候经常会使用EEM,一般咱们是使用SNMP OID去get cpu的值做EEM的触发条件。但是由于OID在不同的IOS下可能会不一样,所以很肯能取不到CPU的值,进而EEM无法触发。
我在设备上发现了另一种EEM的配置方法。原理是通过配置让CPU在高过threshold的时候报一条log,EEM的触发条件是这个log的pattern。
下面贴出配置
process cpu threshold type total rising 85 interval 5 全局模式下配置,命令解释:
process cpu threshold type {total | process | interrupt} rising percentage interval seconds [falling percentage interval seconds]
event manager applet high-cpu
event syslog pattern "CPURISINGTHRESHOLD" 报出的log有这个pattern。
action 0.1 syslog msg "EEM: HIGH CPU detected. Writing info to flash:eem-log.txt"
action 0.2 cli command "enable"
action 0.3 cli command "term exec prompt timestamp"
action 0.4 cli command "term len 0"
action 1.1 cli command "show process cpu sorted | append flash:eem-log.txt"
action 1.2 cli command "show proc mem sorted | append flash:eem-log.txt"
action 1.3 cli command "show mem alloc total | append flash:eem-log.txt"
action 1.4 cli command "show buffers | append flash:eem-log.txt"
action 1.5 cli command "show interfaces | append flash:eem-log.txt"
action 1.6 cli command "show interfaces stat | append flash:eem-log.txt"
action 1.7 cli command "show ip traffic | append flash:eem-log.txt"
action 2.2 syslog msg "EEM: Self-removing applet from configuration..."
action 2.3 cli command "configure terminal"
action 2.4 cli command "no event manager applet high-cpu"
action 2.5 cli command "end"
End
实验:
我是用rack上的RSRP2 (3945)测试的,使用长ping loopback接口IP把CPU冲高,配置如下:
process cpu threshold type total rising 25 interval 5 每5秒检测一次CPU, total cpu utilization 高于25%则报log,log如下:
*Mar 1 05:21:56.354: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr): 30%/0%, Top 3 processes(Pid/Util): 132/14%, 5/10%, 185/0%
Log 中会看到占用最多CPU的3个进程ID和占用CPU多少
然后EEM触发
*Mar 1 05:21:56.363: %HA_EM-6-LOG: High_CPU: High CPU DETECTED. Please wait - logging Information to nvram:high_cpu.txt
看到文件已经抓下来了
RSRP2#dir nvram:
Directory of nvram:/
505 -rw- 3976 startup-config
506 ---- 1912 private-config
1 ---- 35 persistent-data
2 -rw- 0 ifIndex-table
3 -rw- 32048 high_cpu.txt
36 -rw- 557 IOS-Self-Sig#1.cer
37 -rw- 336174 cpu_stats
process cpu threshold type total rising 85 interval 5 <<<<<<< 5秒钟检测大于85
End
如果出现一下提示 可以用""""event manager session cli username """"
more flash:eem-log.txt
Command authorization failed.
并且这个可以跟EEM 连用 直接抓包下来
配置:
monitor capture buffer cc
monitor capture point ip cef cc gX/X both 对应接口
monitor capture point associate cc cc
或者
monitor capture buffer cisco-buf
monitor capture buffer cisco-buf size 10240
monitor capture buffer cisco-buf max-size 1500
monitor capture point ip process-switched cisco-point both
monitor capture point associate cisco-point cisco-buf
process cpu threshold type total rising 85 interval 5 每5秒检测cpu超过85
action 0.8 cli command "monitor capture point start cc"
action 0.9 cli command "show process cpu sorted | append flash:eem-log.txt"
action 1.0 cli command "show proc mem sorted | append flash:eem-log.txt"
action 1.1 cli command "show mem alloc total | append flash:eem-log.txt"
action 1.2 cli command "show buffers | append flash:eem-log.txt"
action 1.3 cli command "show interfaces | append flash:eem-log.txt"
action 1.4 cli command "show interfaces stat | append flash:eem-log.txt"
action 1.5 cli command "show ip traffic | append flash:eem-log.txt"
action 1.6 cli command "show process cpu history | append flash:eem-log.txt"
action 1.7 wait 15
action 1.8 cli command "monitor capture point stop all"
action 1.9 syslog msg "EEM: Self-removing applet from configuration..."
action 2.0 cli command "configure terminal"
action 2.1 cli command "no event manager applet high_cpu"
action 2.2 cli command "end"
评论
Mansur
厉害了。。不过监控我一般都是用的外部的服务器获取snmp,还没在设备上做过
byl_qware_com
Level 8
Level 8
好好学习一下此类型故障的解决方法
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
