取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
ASR1004 ESP10错误,急求大神!
huangpeng0903
ASR 1004,硬件配置如下AME: "Chassis", DESCR: "Cisco ASR1004 Chassis"PID: ASR1004
NAME: "module 0", DESCR: "Cisco ASR1000 SPA Interface Processor 10"
PID: ASR1000-SIP10
NAME: "SPA subslot 0/0", DESCR: "1-port OC3/STM1 ATM Shared Port Adapter"
PID: SPA-1XOC3-ATM-V2 , VID:
NAME: "subslot 0/0 transceiver 0", DESCR: "OC3 SR-1/STM1 I-1"
PID: SFP-OC3-SR ,
NAME: "SPA subslot 0/1", DESCR: "8-port Channelized T1/E1 to DS0 Shared Port Ada
pter"
PID: SPA-8XCHT1/E1 , VID: V05,
NAME: "SPA subslot 0/2", DESCR: "1-port Channelized OC3/STM1 to DS0 Shared Port
Adapter"
PID: SPA-1XCHSTM1/OC3 , VID: V03,
AME: "subslot 0/2 transceiver 0", DESCR: "OC3 SR-1/STM1 I-1"
PID: SFP-OC3-SR , VID: A ,
NAME: "SPA subslot 0/3", DESCR: "5-port Gigabit Ethernet Shared Port Adapter"
PID: SPA-5X1GE-V2 , VID: V02,
NAME: "subslot 0/3 transceiver 0", DESCR: "GE T"
PID: N/A , VID: E ,
1 个已接受解答
已接受的解答
Ta-Jen Hsu
這個應該是 slot F0 的 ESP 卡硬體有問題,建議直接開 TAC Case 辦理 RMA
在原帖中查看解决方案
6 条回复6
Ta-Jen Hsu
huangpeng0903
前段时间设备的critical灯一直红着一直出现报错,不断的出现的:Jan 8 02:05:36.563: %CMFP-3-DDR_SINGLE_BIT_ERROR: F0: cman_fp: Single-bit DRAM
ECC error: mme: 1390509, sbe: 53883183, address: 0x77044760, pid: 5517, name: c
man_fp
Jan 8 02:06:07.645: %CMFP-3-DDR_SINGLE_BIT_ERROR: F0: cman_fp: Single-bit DRAM
ECC error: mme: 1414280, sbe: 54805660, address: 0x77022480, pid: 5517, name: c
man_fp
*Feb 1 05:26:52.418: %CMFP-3-DDR_SINGLE_BIT_ERROR: F0: cman_fp: Single-bit DRAM ECC error: mme: 102328, sbe: 4960921, address: 0x7930B1B0, pid: 5515, name: cman_fp
*Feb 1 05:27:22.419: %CMFP-3-DDR_SINGLE_BIT_ERROR: F0: cman_fp: Single-bit DRAM ECC error: mme: 125450, sbe: 5813878, address: 0x77056C60, pid: 5515, name: cman_fp
huangpeng0903
今天总行的发现这边的链路经常断一会然后在恢复正常,今天中午发现了问题,slot F0的ESP10板卡自动重启,变成offline状态,其他板卡端口都会down,过了三五分钟才会变成online状态,其他端口才恢复正常。
huangpeng0903
设备的ver和platform信息如下:
hr001#sh ver
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-IPBASEK9-M), Version 15.1(3)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 12-Dec-11 15:17 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ahr001 uptime is 3 weeks, 3 days, 1 hour, 59 minutes
Uptime for this control processor is 3 weeks, 3 days, 2 hours, 2 minutes
System returned to ROM by reload at 11:37:12 GMT Fri Jan 8 2016
System image file is "bootflash:/asr1000rp1-ipbasek9.03.04.02.S.151-3.S2.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1004 (RP1) processor with 1756639K/6147K bytes of memory.
5 Gigabit Ethernet interfaces
3 Serial interfaces
1 ATM interface
8 Channelized E1 ports
1 Channelized STM-1 port
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
ahr001#sh platform
Chassis type: ASR1004
Slot Type State Insert time (ago)
0 ASR1000-SIP10 ok 3w3d
0/0 SPA-1XOC3-ATM-V2 ok 3w3d
0/1 SPA-8XCHT1/E1 ok 3w3d
0/2 SPA-1XCHSTM1/OC3 ok 3w3d
0/3 SPA-5X1GE-V2 ok 3w3d
R0 ASR1000-RP1 ok, active 3w3d
F0 ASR1000-ESP10 ok, active 3w3d
P0 ASR1004-PWR-AC ok 3w3d
P1 ASR1004-PWR-AC ok 3w3d
Slot CPLD Version Firmware Version
0 09111601 12.2(33r)XNC
R0 07062111 12.2(33r)XNC
F0 07091401 12.2(33r)XNC
huangpeng0903
由于设备还没有服务,实在是没办法!思科的售后这点很不方便! 麻烦各位大神知道的速度指点,有什么需要的回复。
huangpeng0903
tajen.hsu_cisco 发表于 2016-2-17 11:07 back.gif
谢谢,应该是的。
快捷链接
