取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
Cisco ASA 5510 设备会自动重启
wx_vzmRwaMb
背景:Cisco ASA 5510这款设备只用作于VPN,方便在家办公的同事通过拨入VPN接入内网办公。另一个用途为:A和B(site to site)办公点相互连通形成局域网。
问题:Cisco ASA 5510 设备会自动重启,查看了CPU和内存使用量都不高。
重启频率:大概2天重启一次,多的时候1天都会重启两三次。
麻烦众神归位帮老弟看看啥问题,感谢。如有更好的建议欢迎回复留言,谢谢各位。
以下为A点的信息:
Site-A# show version
Cisco Adaptive Security Appliance Software Version 9.1(5)
Device Manager Version 6.2(5)
Compiled on Thu 27-Mar-14 09:36 by builders
System image file is "disk0:/asa915-k8.bin"
Config file at boot was "startup-config"
Site-A up 8 hours 29 mins
Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz,
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode : CNLite-MC-SSLm-PLUS-2_05
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.09
Number of accelerators: 1
0: Ext: Ethernet0/0 : address is 0024.97fa.d140, irq 9
1: Ext: Ethernet0/1 : address is 0024.97fa.d141, irq 9
2: Ext: Ethernet0/2 : address is 0024.97fa.d142, irq 89
3: Ext: Ethernet0/3 : address is 0024.97fa.d143, irq 9
4: Ext: Management0/0 : address is 0024.97fa.d13f, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 100 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Active perpetual
Encryption-DES : Enabled perpetual
Encryption-3DES-AES : Enabled perpetual
Security Contexts : 2 perpetual
GTP/GPRS : Disabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : 250 perpetual
Other VPN Peers : 250 perpetual
Total VPN Peers : 250 perpetual
Shared License : Enabled perpetual
AnyConnect for Mobile : Enabled perpetual
AnyConnect for Cisco VPN Phone : Enabled perpetual
Advanced Endpoint Assessment : Enabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Enabled perpetual
Intercompany Media Engine : Disabled perpetual
Cluster : Disabled perpetual
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX170180H6
Running Permanent Activation Key: 0xe91ddc59 0x2cbd4741 0x0d42e874 0xe7dcdc80 0x4936c8a9
Configuration register is 0x1
Configuration has not been modified since last system restart.
Site-A# sh memory
Free memory: 700467424 bytes (65%)
Used memory: 373274400 bytes (35%)
Total memory: 1073741824 bytes (100%)
Site-A# sh reload
No reload is scheduled.
Site-A# sh processes cpu-usage sorted
PC Thread 5Sec 1Min 5Min Process
0x08298b79 0xa91d4e14 0.3% 0.6% 0.5% Dispatch Unit
0x090f20ad 0xa91ba1f4 0.2% 0.2% 0.1% ssh
0x08d119ec 0xa91c35a8 0.0% 0.0% 0.0% update_cpu_usage
0x08181ad4 0xa91c6b2c 0.0% 0.0% 0.0% CTM message handler
0x082b303a 0xa91cb1d0 0.0% 0.0% 0.0% Logger
0x0888ad54 0xa91d49cc 0.0% 0.0% 0.0% WebVPN KCD Process
0x093cccfd 0xa91c6f74 0.0% 0.0% 0.0% vpnlb_timer_thread
0x093cc992 0xa91c9c68 0.0% 0.0% 0.0% vpnlb_thread
0x093ac18e 0xa91bdbc0 0.0% 0.0% 0.0% vpnfol_thread_unsent
0x093ac402 0xa91be008 0.0% 0.0% 0.0% vpnfol_thread_timer
6 条回复6
suzhouxiaoniu
1:VPN并发连接数有没有超过限制?之前AP超过连接限制,就会死机重启,所以猜测一下
2:重启有没有对应的日志?和电脑一样,重启信息应该都有保存的
3:版本问题,或者BUG,需要开CASE找具体问题,或者升级版本试试
gejunyu
看下版本能不能更新
wx_vzmRwaMb
gejunyu 发表于 2018-9-13 09:17
看下版本能不能更新
更新系统版本吗?
gejunyu
wx_vzmRwaMb 发表于 2018-9-13 11:20
更新系统版本吗?
ios,新版本的会修复一些问题的
李可
Community Member
遇到同样问题,持续关注
18653465190
跟着学习一下。:)
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
