取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
11
回复
求大哥指点AP登录问题AIR--CAP2602I-C-K9
wongmin2015
遇到一个工程需要搭建一个无线局域网,我购买了2个Air-Cap2602i-c-k9和SF90D-08,因为第一次用,安装思科官网的配置指南用超级终端修改AP的IP地址,不知道怎么进入特权模式(没有看到在哪里登录或者修改模式的),求各位大哥给点意见.(工程现在就差无线网就可以调试了,所有比较急).下面给出超级终端收到的信息,请大哥们帮忙分析分析,拜谢
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP: Macronix Mirrorbit (00C2)
Xmodem file system is available.
flashfs[0]: 10 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 7207936
flashfs[0]: Bytes available: 24790016
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: b8:38:61:ba:70:4e
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...###########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x2003000
executing...
Secondary Bootloader - Starting system.
flashfs[0]: flashfs fsck took 7 seconds.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...#####################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entr
y point: 0x2003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JA1, RELEAS
E SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:08 by prod_rel_team
Initializing flashfs...
flashfs[2]: 10 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31739904
flashfs[2]: Bytes used: 7207936
flashfs[2]: Bytes available: 24531968
flashfs[2]: flashfs fsck took 8 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete.
Copying radio files from flash: to ram:
%Error opening flash:/ap3g2-rcvk9w8-mx/E2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/B2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/V2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/X2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Y2.bin (No such file or directory)
Uncompressing radio files...
File not found: flash:/ap3g2-rcvk9w8-mx/8004.img
File not found: flash:/ap3g2-rcvk9w8-mx/E5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/B5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/V5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/X5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Y5.bin
...done Initializing flashfs.
no ip http server
% Invalid input detected at '^' marker.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-C-K9 (PowerPC) processor (revision A0) with 180214K/81920K by
tes of memory.
Processor board ID FGL1804WAZJ
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: B8:38:61:BA:70:4E
Part Number : 73-14588-03
PCA Assembly Number : 800-37899-01
PCA Revision Number : B0
PCB Serial Number : FOC18037793
Top Assembly Part Number : 800-38356-01
Top Assembly Serial Number : FGL1804WAZJ
Top Revision Number : A0
Product/Model Number : AIR-CAP2602I-C-K9
% Please define a domain-name first.
logging facility kern
logging trap emergencies
Press RETURN to get started!
*Mar 1 00:00:11.323: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Mar 1 00:00:13.019: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar 1 00:00:13.607: %SYS-5-RESTART: System restarted --
E SOFTWARE (fc2)
*Mar 1 00:00:13.639: %CDP_PD-4-POWER_OK: All radios disabled - AC_ADAPTOR inlin
e power source
*Mar 1 00:00:13.647: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Mar 1 00:00:13.651: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
h. Resetting to default config
*Mar 1 00:00:13.655: %PARSER-4-BADCFG: Unexpected end of configuration file.
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:14.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar 1 00:00:16.347: DPAA Initialization Complete
*Mar 1 00:00:16.347: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exite
d
*Mar 1 00:00:16.771: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
1 个已接受解答
已接受的解答
Xin Lei
出厂一般默认瘦AP;你需要转为胖AP才可以使用;
1、用网线连接AP的RJ45口,设置本地电脑网卡IP为10.0.0.2 255.255.255.252 (这个是默认的掩码,可以进入AP:控制台下自己改)
1、对于你想要转换的AP设备找到合适的IOS,如 我转换的是LAP1130 需要先找到胖AP的IOS。
2、重命名该文件名为 c1130-k9w7-tar.default
3、给AP断电,然后按住MODE 按钮不放
4、加电后看到超级终端提示 button is pressed, wait for button to be released..
5、松开mode 键,会进入自动搜索过程
button pressed for 26 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1130-k9w7-tar.default
examining image...
extracting info (275 bytes)
Image info:
Version Suffix: k9w7-.124-10b.JA3
Image Name: c1130-k9w7-mx.124-10b.JA3
Version Directory: c1130-k9w7-mx.124-10b.JA3
这是搜索成功的提示,后面自动解压缩镜像并安装
7、检查一下flash,文件是否复制好;
ap: dir flash:
8、输入boot启动AP:
ap:boot
在原帖中查看解决方案
11 条回复11
Xin Lei
examining image...
Image info:
ap: dir flash:
8、输入boot启动AP:
ap:boot
wongmin2015
顶贴求支持
jing zhang
你这个是瘦AP,有无线控制器么?
如果没有需要降级成胖AP的……
wongmin2015
thousandmoun 发表于 2015-4-12 12:13 back.gif
你这个是瘦AP,有无线控制器么?
如果没有需要降级成胖AP的……
大哥,无线控制器怎么看,怎么降级的
wongmin2015
你这个是瘦AP,有无线控制器么?
如果没有需要降级成胖AP的……
电脑服务器连到SF90D-08以太网交换机上,交换机接的AP
jing zhang
打开TFTP工具,准备好胖AP的IOS(如ap3g2-k9w7-tar.152-4.JA1.tar,把他重命名为ap3g2-k9w7-tar.default)放到TFTP的跟目录下,将TFTP服务器的IP地址改成10.0.0.2到10.0.0.254中任意一个;
然后在关闭AP电源,按住Mode键再开电源,直到AP上出现为一个常亮的红灯,松开mode键,让AP自动下载IOS就可以了,AP本身的默认IP地址为10.0.0.1。
wongmin2015
thousandmoun 发表于 2015-4-12 16:38 back.gif
打开TFTP工具,准备好胖AP的IOS(如ap3g2-k9w7-tar.152-4.JA1.tar,把他重命名为ap3g2-k9w7-tar.default)放 ...
谢谢你的帮助,我想我明白了.那么另一个问题我的是2602i的,请问你有能让我升级的胖AP的IOS文件吗?我邮箱是wongmin2015@163.com,谢谢
wongmin2015
sunlui820522 发表于 2015-4-12 16:46 back.gif
1、用网线连接AP的RJ45口,设置本地电脑网卡IP为10.0.0. ...
大哥,你的回答对我非常有用,非常感谢你.请问大哥你有能供我2602I升级的IOS文件吗?或者你可以告诉我怎么去获得这样的文件.我的邮箱是wongmin2015@163.com,感谢你
Xin Lei
wongmin2015 发表于 2015-4-13 10:07 back.gif
大哥,你的回答对我非常有用,非常感谢你.请问大哥你有能供我2602I升级的IOS文件吗?或者你可以告诉我怎么去 ...
用你的思科账号登陆以下网址可以下载;
https://software.cisco.com/download/release.html?mdfid=284362257&flowid=34153&softwareid=284180979&release=15.3.3-JAB&relind=AVAILABLE&rellifecycle=ED&reltype=latest
yttbxrsxu8095
精英 们:
我还是下载不了这个IOS文件,没有权限下载呀!!!!!。。。。。。。。。谁有能不能发一份到我的邮箱,万分感谢!!!43852530@qq.com
yttbxrsxu8095
下载不了,提示没有权限,我也是刚注册的帐号,哪位有的能不能帮忙发一份到我拉邮箱!!!!谢谢!!! 43852530@qq.com
快捷链接
