取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
help!!SD-WAN C1111-8PLTELA can not commit
xbchen
%SYS-5-CONFIG_P: Configured programmatically by process iosp_vty_100001_dmi_nesd from console as NETCONF on vty32131
3 条回复3
xbchen
help!
What is the configuration that cannot be committed?
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Thanks for your reply!The problem has been solved now.I configured the wrong command under a interface so that it can not be commited.But the command can still be completed when I pressed the tab key , so I mistakenly thought the command does not wrong!
快捷链接
