취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
의견
socui
안녕하세요. 시스코 커뮤니티 여러분,
오늘 공유해드릴 내용은 ESXi 호스트에서 HyperFlex SCVM의 Admin 비밀번호 복구 방법 입니다.
HXDP Version: 4.5(2c)5.0(2a) 및 최신버전에서:
1.1)  ESXi Version >= 7.0의 경우 다음 명령을 사용하여 hxshell에 액세스합니다.
root@bsv-hx-7-A-1:~] ssh -o PubkeyAcceptedKeyTypes=+ssh-rsa admin@`/opt/cisco/support/getstctlvmip.sh` -i /etc/ssh/ssh_host_rsa_key
HyperFlex StorageController 5.0(2b)
hostfile_replace_entries: link /.ssh/known_hosts to /.ssh/known_hosts.old: Function not implemented
update_known_hosts: hostfile_replace_entries failed for /.ssh/known_hosts: Function not implemented
This is a Restricted shell.
Type '?' or 'help' to get the list of allowed commands.
hxshell:~$
1.2)  ESXi 버전 < 7.0의 경우 다음 명령을 사용합니다.
[root@hx-08-esxi-01:~] ssh admin@`/opt/cisco/support/getstctlvmip.sh "Storage Controller Data Network"` -i /etc/ssh/ssh_host_rsa_key
The authenticity of host '192.168.150.232 (192.168.150.232)' can't be established.
ECDSA key fingerprint is SHA256:OkA9czzcL7I5fYbfLNtSI+D+Ng5dYp15qk/9C1cQzzk.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '192.168.150.232' (ECDSA) to the list of known hosts.
HyperFlex StorageController 5.0(2a)
!!! ALERT !!!
This service is restricted to authorized users only.
All activities on this system are logged. Unauthorized
access will be reported.
Last login: Tue Aug 30 11:54:10 2022 from 10.201.254.84
hxshell:~$
2)  액세스 권한을 얻은 후 recover-password명령을 실행합니다.
hxshell:~$ recover-password
Consent token is needed to reset password. Do you want to continue?(y/[n]):
y
1. Generate Challenge
2. Accept Response
3. Exit
Enter Option:
3)  Cisco TAC 팀에 연락하여 생성된 Challenge Key를 보내고 TAC 팀으로 부터 Response Key 를 회신하도록 요청하십시오.
Response Signature Verified successfully !
Response processed successfully.
Consent token workflow is successful, allowing password reset.
Enter the new password for admin:
Re-enter the new password for admin:
Changing password for admin...
Password changed successfully for user admin.
4)  stcli security password set으로 비밀번호를 동기화합니다.
admin:~$ stcli security password set
Enter new password for user admin:
Re-enter new password for user admin:
admin:~$
감사합니다.
참고 동영상: https://www.youtube.com/watch?v=UjKTmVCVrUY
시작하기
상단의 검색창에 키워드, 문구, 또는 질문을 입력하여 궁금한 내용을 찾아보세요.
이곳에서의 여러분의 여정이 훌륭하기를 바랍니다! 시스코 커뮤니티에 빠르게 익숙해지는 데 도움이 되는 몇 가지 링크를 준비했습니다.
빠른 링크
