Which CUCM license is required for Cisco Headset 500 ?
ArSh21
The headsets will be used for contact center, is UCL license required? if so, which license is suitable ? Enhanced maybe ?
Thank you.
Jaime Valencia
The headset doesn't require any license, the devices in CUCM require the license.
java
if this helps, please rate
Jaime Valencia
java
