3221225531_ERROR CODE_AMP
Hi All,
I have received quarantine event failed with the error code 3221225531 in AMP console. I couldn't able to get the exact details for the corresponding event id.
Can some one help me to understand the meaning of this error code.
Wojciech Cecot
The error code you have from Quarantine Failed: 3221225531 is in HEX 0xC000003B : STATUS_OBJECT_PATH_SYNTAX_BAD
https://docs.microsoft.com/en-us/openspecs/windows_protocols/ms-cifs/8f11e0f3-d545-46cc-97e6-f00569e3e1bc?redirectedfrom=MSDN
Usually that means that file was in some network location and AMP couldn't delete it. Please check more details under:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs29250/
-Wojciech
