02-20-2018 12:55 AM - edited 03-08-2019 05:46 PM
hi all,
when i upgrade 6.0.5 or older version to 6.0.7, machines are too slowly and even it does not allow click on desktop.
boot safemod with networking and i uninstall agent, pc go on to work normally.
what is the problem for 6.0.7 ? manually or console upgrade, the same in both.
thanks.
Solved! Go to Solution.
02-21-2018 01:28 AM
Hello ostandal
Do you have Trendmicro running in your environment while using 6.0.7 ?
We have identified the following bug in 6.0.7 version.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi07080/?reffering_site=dumpcr
Jetsy
02-20-2018 01:53 AM
Hello
Is this is happening with normal workstations or just Servers ?
However could you please contact TAC so that we can investigate it further based on the logs.
Jetsy
02-20-2018 02:07 AM
we only deploy workstations. not server.
ok, thanks for answer.
02-20-2018 02:09 AM
02-20-2018 02:05 AM
Not 100% sure but we do have 1-2 cases where customer faces the same issue. Hard part is you wont be able to grab the logs since it makes the system totally unusable. Only way to get access to PC is just uninstall in safe mode.
I'd suggest you provide us the memory dump (through TAC case) following this article when system freezes: https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/forcing-a-system-crash-from-the-keyboard
I tried reproducing this issue in lab but no luck. There is indeed something we need to see and dump logs would be our way to get to the depth of this issue.
Dv
02-21-2018 01:18 AM
We rolled out 6.0.7 to windows computers yesterday, and today we had SERIOS issues with our environment, as users were unable to log on to their computers. We had to deploy a GPO to set the CiscoAMP_6.0.7 service to disabled. Is it possible to roll-back to 6.0.5 in an easy way, or do we have to uninstall/reinstall manually?
02-21-2018 01:28 AM
Hello ostandal
Jetsy
02-21-2018 01:32 AM
hi all,
we solved this problem. if you use another av program, you should be careful advanced protection service is disable or uninstall other av.
because it is overlap other av.
have a nice day.
02-21-2018 01:36 AM
02-21-2018 01:50 AM
Yes, indeed, we have Trend Officescan deployed..
02-21-2018 01:57 AM
02-21-2018 02:30 AM
Hello ostandal
You have to un-install and reinstall to version 6.0.5 and perform a policy sync for the connectors to get the version updated.
Jetsy
