archives not detected
apepacisco
i'm testing  cisco firepower AMP,  it is correct that with a  "malware block" policy  in AMP  all tests   with ecrypted files fail ?
i using this site:
metal.fortiguard.com
it seems to block only plain, tar and cab files.
emirolyu
What do you mean by saying the tests for encrypted files fail?
If you're referring to downloading files through HTTPS, the contents may not be visible, unless you've configured the device to perform decryption. If you speak about encrypted archives, there's a policy (Advanced tab) action to block files, that cannot be inspected.
It's all documented in the config guide: Firepower Management Center Configuration Guide, Version 6.2 - File Policies and AMP for Firepower [Cisco Firepower Ma…
