BUG CSCsm45390 and CSCuw77959
satya mothukuri
Does anyone know exact fix for CSCuw77959 and CSCsm45390 .
i have gone tru all the bug fix note. I didnt get exact answer or work around.
Can anyone please help me with the fix for these two Bugs.
Satya.Mothukuri
satya mothukuri
No one came across these bugs??
did i post in the right place?
AlanRivera30108
I have the same problem
I would be glad to know how to fix these bugs too
dkrull
Greetings,
You will need to update to a newer software version to mitigate this issue depending on your software version (IOS/IOS XE/NX-OS/NX-OS ACI). You can check to see if a new version is affected by using the Cisco IOS and IOS XE Software Checker: https://tools.cisco.com/security/center/softwarechecker.x
I would also recommend reaching out to Cisco TAC to help you find the right software for the version for your device if you are still unsure.
Dmitri Krull
Technical Marketing Engineer - Endpoint Security
dkrull@cisco.com
SSCP - 743085
