Hello @Joshua Heath,
we do not do an automated USB drive OnDemand Scan. This can also be very time and resource intensive, e.g. if you are using a Removeable Storage Device connected using USB 2.0. I know, audit guideline are important, but you may think about the following topics.
There are some interesting things about Signature based detection mechanism we should think about.
- An endpoint can hold millions of unknown files which have not been seen by any AV Vendor. We tested this. You can test this for your own. Just hash your files on a standard system and use the API from virustotal to compare. You will be surprised, how many completely unknown files exist on a system.
- Talos discovers approx. 5 billion unique hashes per week, so you cannot hold any available information in the AV signatures.
- Endpoint products do not a cloud lookup for any file (filetype), this is still not possible. Think about all the non PE files and so on.
- How about Memory Mapped Devices, which are directly mapped into the systems memory?
- New Code or maybe files used for a targeted attack are most time not covered by any AV Signatures.
What we are doing, or, what we are doing more than traditional AV (some info, I´m not aware how familiar you are with AMP).
- We are monitoring file activity and process activity
- We are monitoring network communication.
- We are monitoring command line activity for a process which is directly executed from Removeable Storage.
- All this information is automatically processed in the AMP backend and also calculates IOCs is there is just malicious behaviour. Keep in mind, this also happens if the file just exists on the USB drive for just a few seconds.
- This is also done, if the file on the Removeable Storage is a known clean file.
- If we figure out something bad, the AMP backend generates a retrospective alert.
For Threat Hunting we need the behaviour information for known good files.
Below you can see the monitored activity (process, file, network and command line) from a good file.
Hope this helps,
Greetings, Thorsten
