Hello
I'm working on the deployment of Amp for endpoint on my 10K+ computers.
I just notice a "bad behavior" when running a fullscan.
You may know or not that Onedrive introduce the "fileondemand" option which means that files not used are kept on the cloud and downloaded locally only when the user need/access it.
Running a fullscan with AMP force Onedrive to download all files. It do not only scan file locally present. That's a weird issue coz I don't want a 10Go (up to 1To) onedrive to be downloaded on my client if not needed.
Windows Defender scan works smoothly with Onedrive.
So far the only workaround is to set an exclusion for onedrive folder on AMP which in my opinion is not recommended.
Any help would be appreciated
