Upgrade SSL
dbrill001
So I am running security scans on our network for the first time. I have a long list of things to fix. One is the SSL/TLS suite another is upgrading the key to the diffie-hellman key exchange. I was hoping to get pointed in the right direction on how to disable old unused protocols or upgrade the keys to these protocols.encryption
Seb Rupik
The 3560X software is still being actively developed, the last release was only 4 months ago. 15.2(4)E7 will contain fixes for the most pressing OpenSSL and TLS vulnerabilities. Check the release notes and specifically the resolved caveats:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-2_4_e/releasenotes/rn-1524e-3750x3560x.html#pgfId-1115282
If you want to choose the ciphers used IOS take a look at this document:
https://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v501/command/reference/cmdref/crypto_ssl.pdf
cheers,
Seb.
Seb Rupik
HI there,
It would help to know what platforms you are looking to re-configure. Keep in mind that older platforms will not be able to use 'Next Generation Encryption' so some of the suites will not be available to you.
https://www.cisco.com/c/en/us/about/security-center/next-generation-cryptography.html
cheers,
Seb.
We have 2 3560x Catalysts. I assume by your comment I will be out of luck upgrading these since they are end of life in October.
Seb Rupik
cheers,
Seb.
