ACI and external Firewall Cluster - Recommendation
udo.konstantin
we need a recommendation for connecting a Checkpoint Firewall Cluster to a ACI fabric. It should be a layer 3 connectivity and each Cluster member must be connected to a different leaf switch.
Between the Cluster and the ACI fabric there is a transfer network and the cluster is working in active/standby.
I noticed there are different solutions to solve this.
1. HSRP VIP on ACI side - > CP Cluster has a static route to this VIP
2. SVI on ACI side - > CP Cluster has a static route to this SVI IP Address
...tbd
There is no Portchannel between the fabric and the CP cluster. There are single connections. The CP Cluster has also a VIP configured and each physical interface has its own IP Address. From the fabric there a static routed pointing to the firewall VIP.
Are there any best practices for this design?
Udo
Alexander Deca
Hi Udo,
We did the setup with a CP FW cluster (Active/Standby) spanning 2 different datacenters, we do have vPC's between the CP and the leaf switches per datacenter. We configured a L3Out in the common tenant so this can be used by different tenants (on a per needed base).
We solved this with using SVI interfaces, meaning configuring a /28 for each vPC we have (.1 VIP CP, .2 CP1, .3 CP2 and .4 LF1 [side A IP] and .5 LF2 [side B IP].
