ACI fabric membership learning problem
roysegev
Hello, I encountered a problem when I started registering node members - I can register one and then no other node is pending registration, and I know for a fact the leafs are connected beacause when I remove the registered node I see in the pending node a different leaf. Do you know what can cause that?
5 Replies 5
RedNectar
Hi @roysegev ,
Is this a simulator or real fabric?
If simulator - give your self more RAM and/or vCPUs than suggested
If real fabric - Q2 Is this "out-of-the-box-brand-new" or "reconfiguring-old-fabric"?
If reconfiguring-old-fabric - reset everything as explained in this post
If brand new. Call TAC
RedNectar aka Chris Welsh.
Hi I already reseted all the fabric but it's still not working, and now my registered leaf is in inactive status
Ji @roysegev ,
  1. Is this a simulator or real fabric?
real fabric
Hi @roysegev ,
OK. You've got a real fabric and you've reset the fabric, and you have a "registered leaf is in inactive status"
So my next question is - have you worked through all the checks in the "Troubleshoot ACI Fabric Discovery - Initial Fabric Setup" document?
